Beaver wiring
   / Beaver wiring #1
goat man
satoh Beaver S370
My wiring on my Beaver Satoh diesel S370 is brittle and should be replaced. Is there a wire harness or a diagram available for
these?
   / Beaver wiring #2
Luckily, your tractor is old enough that,, I believe,, it was built before the computer was invented!! :ROFLMAO:
There is not much to the harness,,
I would probably simply hand rewire the tractor,.
Any available harness is as old as the tractor, and,, if not already,
will soon have the same brittle wire problem you already have.:eek:
Starter, glow plugs,, headlights,, that is about all there is.
   / Beaver wiring #3
Agree, you would have to get the wiring harness off and send it to someone to duplicate. Might as well do it yourself if you have it out already. There are companies that make harnesses.
   / Beaver wiring #5
Purchase some spools of good quality insulation stranded copper wire after determining the wire sizes you need. You rarely need anything bigger than number fourteen and number sixteen will probably work for most of it. You can even invent your own color code or do the whole thing in one color and really complicate future troubleshooting. You can replace one wire at a time rather than pulling off the whole harness and trying to figure out what went where. It need not be a difficult project.
Ez-Go Golf Cart (A50121)
Ez-Go Golf Cart...
New 20' Run In Shed (A50774)
New 20' Run In...
2015 JLG Triple-L Flatbed T/A Trailer (A50324)
2015 JLG Triple-L...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2018 Chevrolet Malibu Sedan (A50324)
2018 Chevrolet...
2013 Vermeer V800G T/A Towable Vacuum Trailer (A50322)
2013 Vermeer V800G...
