Grading Beaver owners - Which Box Blade
   / Beaver owners - Which Box Blade #1
DonaldE911
I need a cat 0 box blade to use with my beaver.
I'm building a racetrack in my yard. RC cars not real ones.
What brand do you own... Cost ..
Having a hard time finding a decent model on the net.
Thanks in advance
   / Beaver owners - Which Box Blade #2
Cat 0 equipment isn't very common. You may want to try Northern Hydraulic if you are wanting to order online, but don't be surprized if the shipping is 40% of the cost on a heavy item like that. For a tractor the size of the Beaver look locally at some Cat 1, 4 foot landscape boxes and then try a farm supply store like TSC and buy yourself some Cat 0 lift pins and swap them out. One thing to remember with a landscape box is the heavier it is the better it works. Your Beaver tractor should have no problem lifting a 4 ft heavy duty box. If you think it won't, try a light duty box or add front weights to the tractor.
   / Beaver owners - Which Box Blade #3
I purchased a rear cat 0 scraper blade from tractor supply co ( northern hydraulics also) for @ 125.00 several yrs ago then made sides for it and added a box to the top of the frame to add weight . I t worked great and was able to landscape a 3 acre building lot with ease . I also made brackets on each side to bolt on a flat 6 -8 foot 2x6 to the bottom which acted as a float. after all rough grading was completed i just dragged this floar around to fine tune the grading and fill in small low spots . I f you e-mail me your fax # I will fax a sketch. ---greg
   / Beaver owners - Which Box Blade #4
Just got a Beaver myself, I am simply going to convert my implements to Cat 0 by way of new lift pins - 3 bucks each at TSC. I would recommend getting a 4 ft King Kutter from TSC and switching the pins. Your lift arms should spread wide enough.
UNUSEDX-STAR 72" QUICK ATTACH GRAVEL LEVELER (A51247)
UNUSEDX-STAR 72"...
2015 Ford F-550 Auto Crane 4004EH 4,000LB 2 Ton Crane Service Truck (A51692)
2015 Ford F-550...
2021 SELLICK S80T4E-4PS ROUGH TERRAIN FORKLIFT (A51246)
2021 SELLICK...
2017 HINO BOX TRUCK (A53426)
2017 HINO BOX...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
10' WROUGHT IRON SITE FENCE (A51248)
10' WROUGHT IRON...
