Bearings for Timber Ax?
   / Bearings for Timber Ax? #1
allaboutmowing
Fort Worth Texas
Cat 256c xps high flow cab, Kubota 9540 cab
Anyone have any aftermarket ideas or links to get the drum bearings for the Timber Ax? They are about $460 from my local dealer.
   / Bearings for Timber Ax? #2
Is it a 'special' type of bearing ?
Don't know about your area, but a "bearings-are-us" type of supplier near me has never let me down yet.
I walk in with the old one and 'usually' leave with a replacement in hand.
   / Bearings for Timber Ax? #3
They are a double row spherical (self aligning) bearing , more than likely metric and are quite expensive . My machines run 2233 bearings and are around $180 AU each , I would think they would be a lot less over there . Make sure you don't over grease them , they will fail prematurely . As Willl said , any bearing center can supply them , either by part number or measurements .
   / Bearings for Timber Ax? #4
Sometimes there will be a part number on the bearing itself that can be cross referenced.
UNUSED CHERY INDUSTRIAL 14' BI-PARTING IRON GATE (A51248)
UNUSED CHERY...
UNUSED JCT HD HYD BACKHOE ARM (A51248)
UNUSED JCT HD HYD...
NEW HOLLAND TN75SA TRACTOR (A51247)
NEW HOLLAND TN75SA...
2016 John Deere 35G Mini Excavator (A52377)
2016 John Deere...
2022 Wacker Neuson SM100 Mini Skid Steer (A53472)
2022 Wacker Neuson...
U56 ELECTRIC FIRE PUMP MOTOR (A51406)
U56 ELECTRIC FIRE...
