TheRooster
Anyone ever replaced the bearings on the drive sprocket shaft (connects to the PTO) on a 47" snow blower? My blower began making more noise than usual this past season, it also began shearing pins between the auger and the impeller. Everything turns freely, but I noticed that I was almost maxed out on the chain tightening, and it just wasn't sitting well on the larger chain sprocket. I thought the shaft the that the drive sprocket was bent (although I don't see how, it's pretty sturdy) because the collars that seat and hold the bearings against the housing are were "wobblying" when I turned it after taking it out of the housing. It's an interesting design in the way the collars "center up" on the bearing to hold it in place, but they are very mobile once you take all six bolts out - kinda wish it was a classic washer/bearing/collar set up, but I'm no JD engineer. The now unbolted, loose collar is what made it look like it was bent.
SO, everything seems to be straight, I've ordered a new chain (both sprockets look fair), but in the event that I have to replace the smaller drive sprocket, I think I have to take at least one bearing off... Are they pressed onto the shaft? There are two spin tight collars with set screws on either side of the sprocket in between the bearings, but I can't see what they're holding, specifically, unless they're just spacers to keep the sprocket in the same place related to the bearings.
I can send a pic if needed, but wanted to get some feedback if anyone had already had to replace that drive sprocket. Thanks in advance for any help/suggestions.
