Mowing bearing on mower deck needs replacement
   / bearing on mower deck needs replacement #1
lukas2000
I broke the drive belt on the mower deck and thought it was a bad belt but I found the drive pulley bearings ceased. Luckily I didn't ruin the new belt any advise on how to pop the bearings out . This is the main pulley on the lawnmower deck are these bearing standard size with an upper and lower pulley . the model is 1610 hydo 16hp brigs hydrostatic drive 48 inch deck
   / bearing on mower deck needs replacement #2
Sorry "Lucas2000" ya really gotta help us out here..There has been literlly hundreds of Cub Cadet models made and a zillion decks produced..Please give us a hint of your model,size, /forums/images/graemlins/confused.gif
   / bearing on mower deck needs replacement #3
</font><font color="blue" class="small">( the model is 1610 hydo 16hp brigs hydrostatic drive 48 inch deck )</font>
although i have no idea about you particular mower, the information is pretty much good for all mowers
should be regular bearings, good to get from local mower dealer. seem they are busted anyway, beat them out with your favourite tool, you dont need to save them. take the part no, found on the bearing casing to the dealer and he should have em in stock
one thing to check, when you replace them make sure they are a tight fit to the mandrel or they aint no good. if loose use coke can to make them a tight fit /forums/images/graemlins/laugh.gif
hope this helps
   / bearing on mower deck needs replacement #4
Your bearings will have a number on the outside flange. Get that number and call your local bearing company. They can get you a replacement if your dealer does not have them. Probably will be cheaper than the Cub dealer too.
   / bearing on mower deck needs replacement #5
</font><font color="blue" class="small">( I broke the drive belt on the mower deck and thought it was a bad belt but I found the drive pulley bearings ceased. Luckily I didn't ruin the new belt any advise on how to pop the bearings out . This is the main pulley on the lawnmower deck are these bearing standard size with an upper and lower pulley . the model is 1610 hydo 16hp brigs hydrostatic drive 48 inch deck )</font>
The Cub replacement part is the Spindle Asm PN-759-3479, which includes the bearings, shaft, mounting flange etc. They are expensive - $70.25 each back in June, 2000. The older spindles were ball bearing and the later ones have roller bearings. I had to replace all three on a 44A mower deck due to slop in the bearings. If you have a lot of time and access to a bearing press you may be able to dissassemble them and find replacement bearings.
Bob B.
2016 FREIGHTLINER CASCADIA TANDEM AXLE 6X4 MID ROOF SLEEPER TRUCK (A51219)
2016 FREIGHTLINER...
New Kivel Single Skidloader Spear (A50774)
New Kivel Single...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
2018 FREIGHTLINER CASCADIA (A50854)
2018 FREIGHTLINER...
BREWSTER DRAWWORKS WITH TWIN CATERPILLAR ENGINES (A50854)
BREWSTER DRAWWORKS...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
