Bearing material.
   / Bearing material. #1
Rio_Grande
Platinum Member
The Cultipacker I am reworking needs new bearings. The old ones look like bronze, or an off color brass.
I have looked at several options and they are all outrageously expensive. What is everyone else using in this enviroment to get this old stuff running again?
Jeff
   / Bearing material. #3
Depending on the size bearing you need there may be bronze bushings the correct size available from supply houses like McMaster-Carr.
There are many different types of bearing material available depending on the hardness of the shaft that is turning inside the bearing. You may be able to find a local machine shop that will make the parts you need, most of them are pretty hungry for work and might cut you a deal.
Randy
   / Bearing material. #4
Don't be tempted to make them out of brass: it's terrible as a bearing material and generally only ever gets used due to confusion with bronze.
A fair few machinists will probably have some bronze bar in stock... do you have anyone local machinists you know of? A crate of beers would usually get that sort of work done over here.. :thumbsup:
   / Bearing material. #5
You might consider oil impregnated bronze:
http://www.anchorbronze.com/sinteredbronze.htm
I had good luck with this material for a pilot bearing for an automotive transmission input shaft. Do a quick PV calculation and see if it makes sense. Do the bearings have any kind of dust seals? I'm not familiar with cultipacker construction - they seem pretty minimal/simple.
-Jim
   / Bearing material. #8
I'm curious as to what type of bearings are needed and exatly what "options" the OP means?
I agree that it sounds like bronze and it's likely that they are a standard size...I've replace them in several old table saws...
Bronze bearing (not solid bronze) is porous and there is usually an oil hole in the casting or journal etc that is used to saturate the bronze bushings..
For wood bearings....
scroll down to "uses" (4th paragraph)
Lignum vitae
   / Bearing material. #9
What kind of speed, ID, OD are we talking about? I just scrapped an old cement mixer that has been running (off and on) for twenty years with a simple oil soaked spruce wood bearing....
   / Bearing material. #10
I got a disc with old grey iron bearings.. :)
soundguy
Pair 2 - ST225/75R15 radial trailer (A53421)
Pair 2 -...
Stainless Steel 1" Spool (A52377)
Stainless Steel 1"...
2015 MACK CXU613 (A53843)
2015 MACK CXU613...
Trojan 8T-50 46in Hydraulic Thumb Excavator Attachment (A51691)
Trojan 8T-50 46in...
KUBOTA SVL97-2 SKID STEER (A52705)
KUBOTA SVL97-2...
TMA (A49461)
TMA (A49461)
