BearCat Chipper/Shreader Any Good?
   / BearCat Chipper/Shreader Any Good? #1
Artisan
Veteran Member
Monrovia, California
Kubota BX25
Gents I am looking for input re: a #554 BearCat Chipper Shreader as
pictured. Are they good, bad, don't waste my money? Go for it,
do you own one, easy to sharpen? Is it true there are 3 differernt models
per your PTO speed? 540, 1000 and 2000? (PTO RPM's)
   / BearCat Chipper/Shreader Any Good? #2
I'll tell you tomorrow. I just got a really clean used one. But, I will be powering it with a TC40D; 40hp/35 pto/hp
   / BearCat Chipper/Shreader Any Good? #4
I have a Goossen Chipper-shredder that looks very similar to the BearCat. I would not be surprised if one or the other company makes them both. I have been happy with mine although I don't push the chipping capacity much. I shred up small twigs but I mostly use it for leaves, as it makes them easier to compost and prevents them from matting up. i I mostly run cedar through it as it tends to hold up better as mulch. I never chipped much of any hardwood as that's mostly firewood unless they are twigs. It is a bit of a pain to get to the blades, but all told I think they are well built.
   / BearCat Chipper/Shreader Any Good? #5
Yes, these are real good chipper shredders. Lots of threads about that model. The Woods 5000 is the same unit made by Bearcat. Not sure on the model#'s andpto speed.
Matt
   / BearCat Chipper/Shreader Any Good? #6
Do a search. Lots of threads on that model be it BearCat or Woods. You will find all of the operating techniques, blades, sharpening, and other answers to your questions.
I have that exact model. One of the best small chippers built in my experience and in the opinion of others.
Don't know about the different PTO speeds.
Roy should be here any moment to elaborate.
   / BearCat Chipper/Shreader Any Good? #7
They are real good. A possible downside to that model is the lack of a proper discharge chute, but I can't see that part from your picture to know. I wouldn't let that stop me from buying if it was a good deal. I seem to recall that a chute can be added separately, if desired.
   / BearCat Chipper/Shreader Any Good? #8
Here's a link to the product manuals:
ECHO Bear Cat | Product Manuals
The model number is 73554.
My Woods 5000 (same as the 73554 and manufactured by Bearcat) operates at 540 RPM only...the manual is quite specific about that.
Your BX25 has 18 PTO HP...that's a little low (15 PTO HP is the recommended minimum) but you should do fine with branches up to 2.5" or so.
As others have written, these are great chipper/shredders for residential use. I found I use the shredder as much or more then the chipper.
Also, as others have written, there are numerous threads on these machines, including RobertN's current thread (so I'm not going to repeat what I wrote there).
BTW, have any of you folks modified your Bearcat or Woods for Quick Hitch compatibility? If so, can you post pics? I've got some ideas how to do it, but nothing wrong with seeing how others have.
   / BearCat Chipper/Shreader Any Good? #9
Down sides.
Manual feed. If the blades are dull or the wood is dry or hard it will work you.
Chips discharge under chipper. If you chip a lot you will have to move the machine or shovel chips. If you want to use the chips you have to load them into a trailer.
Feeding debris to be shredded past the brush guards is a pain.
Blades need to be sharp for this unit to work well. You will need special equipment to get them really sharp or to take them to a good sharpening shop. When they are sharp they are razor sharp. They will shave you.
These are good heavy duty machines that are pretty trouble free.
Chris
   / BearCat Chipper/Shreader Any Good? #10
Excellent machines. I've got one. If you can get in in, it'll chip it. Run off 37hp/35pto kubota.
PALLET OF 3 DEF TANKS (A45046)
PALLET OF 3 DEF...
AGT QK16R Mini Excavator (A44501)
AGT QK16R Mini...
SMOOTH BUCKET (A45046)
2013 KENWORTH T800 MID-ROOF SLEEPER (INOPERABLE) (A45333)
2013 KENWORTH T800...
2017 PETERBILT 579 (INOPERABLE) (A45046)
2017 PETERBILT 579...
New/Unused Pallet Forks (A44391)
New/Unused Pallet...
