Bearcat 73554 on a JD2520
   / Bearcat 73554 on a JD2520 #1
Piedmont
NC, USA
JD 2520
My dealer said I would be pushing it on the PTO power with this chopper shredder but the specs say no problem to me. What's your take? Anyone have this setup already?
Bearcat says PTO of 540 RPM's
   / Bearcat 73554 on a JD2520 #2
I'm running a Bearcat 70554 chipper/shredder with a Yanmar 186D 18 hp engine 14 hp pto. I have done a lot of work with it but I often wish I had more horse power. I can stall the engine if I feed a big limb too fast especially if it is hard wood. That is probably what the dealer means. You can do it but you may wish you had a bigger tractor.
Chris
   / Bearcat 73554 on a JD2520 #3
I've been running a 73554 on a TC18 - 14 PTO HP. No problem unless you run a 4-5" dry hardwood thru - then it bogs down after about 4 feet. A quick pull back will let the engine recover.
Here is my review with some pix chipzilla
Toro Workman Utility Cart (A51694)
Toro Workman...
378748 (A51573)
378748 (A51573)
2018 Nissan Pathfinder SUV (A50324)
2018 Nissan...
2019 Chevrolet Malibu Passenger Car, VIN # 1G1ZC5ST5KF136071 (A51572)
2019 Chevrolet...
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
43014 (A51691)
43014 (A51691)
