Bearcat 73554 I-Match Quick Hitch Conversion
   / Bearcat 73554 I-Match Quick Hitch Conversion #1
larry8818
Bronze Member
John Deere 2520
Attached is a slideshow of pictures that I have taken during this conversion.
It really wasn't too bad, but drilling 1/4" steel is like you know...drilling 1/4" steel.
Anyway, here's the stock list:
1 = $40.00 quickhitch bushing kit
2 = $6.50 1/4" * 5" * 4" steel bar stock (local welding shop cut it on site)
1 = $3.50 4" Quick pin with spring pin
2 = $7.43 5/8" * 1 1/4" Hex bolts, 5/8" washers & locknuts
1 = $15.97 5/8" drill bit (my set only went up to 1/2")
1 = $19.98 3/4" drill bit
1 = $24.96 Dolly (if converting to quick-hitch, unit has to be raised to be removed from tractor).
$118.34 Total, I know...I could have got the whole Harbor Freight quick-hitch with the adj. top link for $79.99 and saved almost $40...****, JD missed the ball on this one. From JD you pay $225.00 and no adj. top hook, and Harbor Freigth you pay $79.99 and get an adj. top hook. If I only knew then what I know now...I would have gone the Harbor Freight route and save the $145...then deduct a couple of bucks for a can of JD Green spray paint and we're good to go.
The pictures pretty much speak for themselves...but ask if you have any questions.
This project was a bear having to drill the 1/4" plate with 3/4" holes 6 times, and the factory member 1/4" with 3/4" holes twice. That a total hole of 3/4" * 2" deep! My bits even with oil, and I mean a lot of oil, were not very happy. I drilled pretty much what I could in a drill press. I also had to use a sawzall and cut down the top busing to fit in between the plates. They had to be cut down to 1 1/2".
This project was well worth the time. I can put this unit on in a snap now...maybe in my near future that JD I-match auto hitch may be looking pretty good.
  • Bearcat 73554 I-Match Conversion.pdf
   / Bearcat 73554 I-Match Quick Hitch Conversion #2
Well Done Larry! Makes me glad I've got the HF adjustable quick hitch. I store mine on a pallet to fix the height issue.
Tye 4 Shank Taratill (A50514)
Tye 4 Shank...
(INOP) CATERPILLAR TL943 TELESCOPIC FORKLIFT (A50459)
(INOP) CATERPILLAR...
1968 International Harvester 856D 2WD Tractor (A50657)
1968 International...
2016 Ford Focus (A50324)
2016 Ford Focus...
2008 New Holland B110 MFWD Loader Backhoe (A52128)
2008 New Holland...
JOHN DEERE MAX EMERGE 2 (6) ROW PLANTER (A51243)
JOHN DEERE MAX...
