BCS throttle control
   / BCS throttle control #1
ottawarob
Ottawa, Ontario
BCS, MF 1540
The past while, the throttle thumb shifter on my bcs hasn't been holding it's place well. Yesterday it got really bad - you'd throttle up, then it'd fall right back to near idle - super annoying. Remembering friction shifters from bicycles, I tightened up bolt holding the throttle control, seems to be better now. Wondering if you guys have had this happen before - I'll be super happy if this fixes it in the long term.
   / BCS throttle control #2
I have the same problem with a near-new (not quite 2 tanks of gas yet) BCS 852. The throttle doesn't have the same adjustment as the other cables. I took a wee bit of slack out of the other end of the cable, then tightened that same bolt (assuming you're referring to the wide slotted bolt just inside the throttle control. The best I can get is for there to be a little slack on either end of the throttle, but at least it stays up near full throttle now. It may be that the problem is ameliorated over time as the spring on the throttle near the carb relaxes a bit.
Any other ideas you have, I'm happy to hear. My brake on one side hasn't been working well, now isn't working at all, and is starting to make some noise. I need to fix that before I use it again. It's a cool machine, but I'm not wild about having to deal with these things on a brand new $5k machine. I'm hoping that it all settles in and becomes a very reliable piece of equipment that doesn't need constant tinkering.
2022 JOHN DEERE 6120M LOT NUMBER 192 (A53084)
2022 JOHN DEERE...
THIS WILL BE A LIVE VIRTUAL ONLINE AUCTION! (A53342)
THIS WILL BE A...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A53472)
2019 New Holland...
2021 Caterpillar 428 4x4 Extendahoe Loader Backhoe (A52377)
2021 Caterpillar...
New/Unused 72in Quick Attach Skid Steer Mulcher (A51573)
New/Unused 72in...
