BCS plough and steel wheels, will they fit Grillo?
   / BCS plough and steel wheels, will they fit Grillo? #1
texanjim
Wales
McCormick CX105, McCormick CX95, Case 1494, Grillo G85D
Hi there,
Does anyone know whether the wheel stud pattern on a BCS 735 is the same as a Grillo G85D? I have my eye on a set of steel wheels from a 735, but unsure if they'll fit my machine. (image below)
Also, would this plough and tool carrier fit the G85D too?
I have a hunch they should all fit fine, but I know there are more knowledgeable people on this forum!
Many thanks
   / BCS plough and steel wheels, will they fit Grillo? #2
You'll have to drill out the holes bigger, but the pattern is the same. The plow should bolt up, too. If it doesn't, then you need to find the right hitch.
Great, thanks for the info farmerboybill. That's good to know, and interesting about the wheels. I hadn't even considered that the studs would be a different diameter.
Unfortunately, they were at such a good price they had sold in the time it took me to write the original message on here! I would have just bought them when I saw them, but they were a 4 hour drive away so wanted to be sure.
I'll keep looking with your advice in mind.
Thank you
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
2019 TAKEUCHI TB230 EXCAVATOR (A51246)
2019 TAKEUCHI...
EASTWOOD MIG250 WELDER (A51248)
EASTWOOD MIG250...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2024 REMLINGER 2300 LOT IDENTIFIER 200 (A53084)
2024 REMLINGER...
Sullair 185 (A50123)
