Bcs or Grillo diesel vs gas?
   / Bcs or Grillo diesel vs gas? #1
Dsl power
Minnesota
BCS 735
Just wanting experiences with problems or like and dislikes of the 2 wheelers with diesel engines? I'm a big fan of diesel engines just love the way they sound and run! Any and all opinions and experiences are welcome.
   / Bcs or Grillo diesel vs gas? #2
Don't have one but I was told you had to work it a lot to break even, But even so I want a diesel.
I use them for just about everything so break eve shouldn't be an issue. I put around 400hrs a year on my old 735. I have a very large diesel tank at my place to fill from so diesels are what I like to have for engines for simplicity sack.
   / Bcs or Grillo diesel vs gas? #4
I have lots of diesels around but, it was hard to justify the cost. I almost bought a used one, but in the end I went with a new Grillo 107D with the Honda because it was the best value and I liked the tiller design much better. I also liked the fairly low noise of the Honda.
I would love to have a new 853 diesel, but I just couldn't swallow the cost with the gas Grillo option that is such a capable machine at about half the cost.. Maybe if it was my only tractor, but I have other diesel tractors already. I guess it really depends on how many hours you put on per year, I'm probably around 50 or so.
   / Bcs or Grillo diesel vs gas? #5
I went thru the same thoughts and ended up with a 853 diesel. I run mine several time a week so it was a good choice. Where I live flat ground is rare and the diesel does better on the slopes. If I had it to do over again I still would go diesel.
I have very steep slopes here and full pressure lubrication is one of the things I like about the diesels and I can even put a pressure Guage on them which I want for my own piece of mind.
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
2017 Jeep Wrangler (MPV), VIN # 1C4BJWDG2HL674841 (A51572)
2017 Jeep Wrangler...
2024 JOHN DEERE 461M LOT NUMBER 62 (A53084)
2024 JOHN DEERE...
