Hi again Peter
I fully agree with the above comments. You could save yourself a lot of trouble my using one of the many proven brands, like the ones mentioned in the BCS America Service Bulletin 2-22, or in the list provided by Maxxjod here:
http://www.tractorbynet.com/forums/...owersafe-clutch-bcs-11.html?highlight=maxxjod
As you seem to have dealers in your area selling the Castrol and Kubota products, you should easily be able to get one of the types mentioned above. I dont think that you are looking at it all wrong, but I think that you are perhaps making it more complicated for yourself than necessary. There are so many proven products to choose between, some of which are also available in your area, that I dont see why you should take the risk of using what might turn out to be the wrong one.
Whether the Limited Slip version of the Castrol oil is a better choice or not, is hard to tell. This oil is not on the above mentioned lists, so why take the risk? It might be the better choice for some applications, but as it isn't recommended for the BCS tractors, I would not use it.
On a traditional
mechanically activated clutch - like the one on the non-PowerSafe BCS models for example - the clutch parts are pressed together by powerful springs, enabling the clutch to transfer torque from the engine to the drivetrain. By squeezing the clutch handle towards the handlebar, you compress the springs, disengaging the clutch, by allowing the parts to rotate separately. The PowerSafe clutch ist still a mechanically clutch, but it is
hydraulically activated! Instead of springs to provide the force needed to engage the clutch, the PowerSafe clutch has a little oil pump that provides pressure to force the parts together. Disengaging the clutch at the clutch handle, simply opens a valve, interrupting the oil flow to the clutch, allowing it to open. This is also the main reason, that it takes so little effort to disengage the clutch on the PowerSafe models, as you simply open the little valve, instead of having to squeeze a number of powerfull springs.
The PowerSafe clutch is a wet type clutch, running in the same oil as the oil pump is using to engage the clutch, and I feel confident that the engineers at BCS have had their reasons to recommend the type of oil that they do, to make sure that it fulfils both the requirement for the pump and the clutch at the same time.
Whatever type of oil you decide to go for, it would be nice to hear about your experience later on. That could be another chance for all of us to learn something new :thumbsup:
Best regards
Jens
