Maine Hills
Bronze Member
- Joined
- Apr 12, 2016
- Messages
- 65
- Location
- Midcoast Maine
- Tractor
- Kubota B2650 BCS 749 Kubota RTV X1120
Since this is the time of year many folks are considering purchasing two wheel tractors and implements I thought I'd start a thread with our experiences. I'll make several posts to keep the individual posts from becoming too long.
Two years ago we purchased a BCS 749 tractor, a BCS duplex 59" sickle bar mower, and a Berta 34" flail mower. Last year we added a BCS 32" rotary cutter. This year we added a BCS 30" tiller The tractor has am electric start Honda 13HP engine, optional 6.5x12 tires, and two pairs of wheel extensions. The BCS tractor and mowers were purchased to mow the portions of a former pasture which are too steep or rough for me to mow with a four wheel tractor, and also mow every other year an acre of wild blueberry "barrens" which is currently inaccessible to a four wheel tractor. The former pasture is are on a hillside in Maine with grades up to twenty five percent, along smaller, steeper embankments, bumps and holes. The soil is full of rocks, and has numerous wet areas. The area mowed about five acres. The sickle bar mower was used for the most of the mowing which was grasses and similar vegetation from three to six feet tall in open spaces. The flail mower was used for clearing brush and mowing in more confined spaces, including the bottom of a drainage ditch. The tiller will be used to prepare plots and beds for planting, and also to loosen soil prior to smoothing in areas which are rutted or have large humps.
We decided on the 749 because we wanted a differential, individual wheel brakes, and an engine powerful enough for the 34" flail mower and the 59" sickle bar mower. A fourth "transport" speed was not a consideration for us as the land is steeper than I'd want to ride behind the tractor on a cart or sulky. That narrowed the choice to the BCS 852/853 with dry clutch, and the BCS 749 with the "Powersafe" hydraulic clutch. At the time of purchase Diesel engines were still available but we quickly decided on the Honda gasoline engine due to lower initial cost, much lower replacement cost if needed, and less weight on the back when the tractor is used for mowing. The tractor decision for use came down to the BCS 853 with the dry clutch, or the BCS 749 with the Powersafe wet clutch, both with the 13 HP Honda gasoline engine . We decided to go with the 749 with the Powersafe though I expect either would have been fine for us.
