BCS 740 braking power
   / BCS 740 braking power #1
marnebcs
Auenland
BCS
Hello Folks,
so I purchased a BCS740, so far so good, the machine seems to be in good overall shape and runs nice.
As I never owned or used a two wheel tractor I have no clue about the braking performance.
If I lift the unit, the brakes seem to stop the wheels fine, but when the machine is driving, I can't use the brakes to stall the engine or stop it, no matter how hard I pull the levers, the machine keeps pulling.
As I have a heavy 300lbs stone burrier implement, using the brakes left/right as steering support doesn't work satisfying, which probably is caused by the stone burrier's rear-roller.
Is this usual behavior of a 740 or are my brakes somewhat worn or shot?
Any thoughts are welcome!
Many thanks.
   / BCS 740 braking power #2
They're not stopping brakes, they're steering brakes. Mostly they're for steering the machine while mowing, so are unlikely to give much satisfaction with a heavy groundbreaking implement. If you pull the tires off your machine and look at the little shoes and drums, you'll see what I mean.
Many thanks Bill, good to know the unit is allright, those drums are really tiny.
Cheers
Marne
2014 FORD Transit Connect CARGO VAN (A50323)
2014 FORD Transit...
2022 Ford F-150 Pickup Truck (A51692)
2022 Ford F-150...
KUBOTA M6800 TRACTOR (A51247)
KUBOTA M6800...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
Toro Zero Turn (A50324)
Toro Zero Turn...
2012 FORD F450 SERVICE TRUCK (A53426)
2012 FORD F450...
