BCS 725 Clutch
   / BCS 725 Clutch #1
atallthinman
The clutch on my BCS 725 does not work. Nothing happens when I use the lever. Does anyone know what is wrong and how I can fix it? It is rather difficult to use without the clutch working.
   / BCS 725 Clutch #2
I went through the stuck clutch experience last year. Below is the postings from the Yahoo BCS board regarding how to unstick a BCS clutch. Please note Rob's advice about always storing the BCS with the clutch lever depressed. This keeps the clutch facings apart and thus prevents the rusted together sticking problem.
Bill in NC
Re: BCS Clutch
Rob, you are the man! I did as you suggested and bingo,
the clutch is working like new. I heavily sprayed WD-40
into the holes on the output end and then put a large
socket over the output end so as to damage the output
connector (looks like the inside of a socket wrench) and
then put the assembly front-to-back inside a large vise.
WD-40 was liberally sprayed in the side holes around the
clutch body. I cranked down the vise and let it out about
ten times while continuing to spray WD-40 into the holes.
You can feel the clutch action loosen up after cranking
down and letting out several times. Note: you can only
crank down to the internal clutch stops which are visible
through the side holes.
The clutch now works smooth and easy.
Rob, thanks for the technical advice. I owe you.
Bill in NC
-- In BCS_Users@yahoogroups.com, "Rob McDowell" <redwine@...> wrote:
> Bill,
> The first step is to put it in a vise and try to squeeze it open, using
> WD-40 through the holes. If, and likely when, that doesn't work, place it
> on a block and using a piece of wood as a pad strike with a hammer, gently
> at first. It took a a full swing with a 5 lb sledge for me. Been fine
> since (5 yrs of heavy use). Always keep the clutch disengaged (open) when
> not in use.
> Rob
   / BCS 725 Clutch #3
The clutch is stuck on my 725. There is an adpater plate between the engine and tranny, does it matter which set of bolts I remove?
   / BCS 725 Clutch #5
Hey thanks, that helps a lot. My machine is from the early-mid 90's so wasn't sure exactly what to expect. I tried rototilling with it for a while yesterday to see if that would break it loose and it didn't so it must be stuck pretty good. I knew about locking the clutch in the disengaged position but loaned it to my son for a while and I either forgot to tell him or he forgot to do it. Do these have a shear pin/bolt? Or are they dependent upon the clutch slipping when its not stuck?
Same thing happened to me and a member sent me the following guide from BCS:
http://bcsamerica.com/pdfs/serviceinfo2-6clutchstuckinengaged.pdf
Hope it helps.
   / BCS 725 Clutch #6
   / BCS 725 Clutch #7
So I followed the advice on releasing the clutch on my BCS 725 but now I have a problem. It is now working the opposite way! Pull lever in and you have drive. Release lever and no drive! Any ideas?!?!
2007 POWERSCREEN CHIEFTAIN 2100X INCLINED SCREEN (A53426)
2007 POWERSCREEN...
2019 HYUNDAI HX300L EXCAVATOR (A51246)
2019 HYUNDAI...
JOHN DEERE LOT IDENTIFIER 69 (A53084)
JOHN DEERE LOT...
(2) VISSANI REFRIGERATORS (A51248)
(2) VISSANI...
2011 Mack CHU613 T/A Wet Kit Day Cab Truck Tractor (A51692)
2011 Mack CHU613...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
