BCS 715 with Acme 290 WB problems
   / BCS 715 with Acme 290 WB problems #1
mbrianb
Thousand Oaks, CA
bcs715
I can start the engine and it will run at almost any speed for about 5 minutes. Then it starts to surge and finally quits.
I have cleaned, soaked, and rebuilt the carb several times and it keeps doing the same thing. I have been able to hold the governor lever open when it starts to surge but eventually it just quits again.
If it sits for a while it will re-start and then do the same thing again. The fuel line is open as I am able to drain the tank by removing the hose from the carb, this tells me that it is not the gas cap as has been posted in other threads.
The surging seems to indicate a carb problem but it runs strong for about five minutes before acting up. It might be the coil but I don't know where that is or how to check it. When it surges it is not like turning a switch on and off (electrical). its more like running the throttle up and down. When it is surging there is some misfiring on occasion.
Any ideas would be appreciated.
Where can I get another carb for this beast if needed?
   / BCS 715 with Acme 290 WB problems #2
I think that motor has points that have to be set. They may be heating up and acting funny...
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A51247)
UNUSED CFG...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
PALLET OF ARMSTRONG CEILING INSULATION (A51248)
PALLET OF...
20711 (A50323)
20711 (A50323)
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
UNUSED FUTURE BD43 HYD BACKHOE ATTACHMENT (A51248)
UNUSED FUTURE BD43...
