BCS 715 rough engine speed
   / BCS 715 rough engine speed #1
sikboater
I bought a 1982 Mainline BCS 715 (ACME AL 290 motor) a few weeks ago and the engine seems to run rough when running at anything above an idle...
I have taken all the jets out of the carb and soaked them in carb cleaner, tried with the air filter and without, and played with all the adjustments I can find. I have the engine and carb break down from Earthtools to make sure I took everything apart I could find... I have replaced the spark plug also.
The funny thing to me is that it idles nice and smooth but as soon as you give in more throttle it kinda sputters and runs rough. It does not stall though and if you load it (rototilling) it runs better. I seems to me that it is getting too much fuel but I don't know for sure. I have also cleaned out the bowl and screen going into it...
Does anyone have any other suggestions? Ideas on what could be wrong?
Thanks in advance!
Tim
   / BCS 715 rough engine speed #2
This motor has points and condenser. They may need adjustment or changing.
   / BCS 715 rough engine speed #3
Thanks in advance!
Tim
Your mules engine is olde enough to need:
1. Unsire if the Acme's are like the briggs engines
but you may need;
plug(s)
(points or condenser)
coil
in line fuel filter-works wonders
Add seafoam to the gas and let it soak and add seafoam to the fuel as you get more fuel
(unless you buy fuel from a marina that does not have that ethanol crap in it)
_________________________________________________________________________
Once you go flail you never go back:thumbsup::licking::drool:
Pronovost or not at all!!!:thumbsup::licking::drool:
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
2003 Atlas Copco 75kW ABB Rotterdam 220psi Air Compressor (A52377)
2003 Atlas Copco...
2020 Nissan Rogue SUV (A51694)
2020 Nissan Rogue...
2017 Ram ProMaster City Cargo Van (A51692)
2017 Ram ProMaster...
2017 Ford F-450 XL (A50123)
2017 Ford F-450 XL...
John Deere GR72B (A50123)
John Deere GR72B...
