BCS 715 Clutch is stuck
/ BCS 715 Clutch is stuck #1
coaster
Virginia
BCS 715
I have a 715 with a stuck clutch. I've removed the engine, but I think to remove the clutch the hex nut is on the side of the clutch versus inside the clutch/down the shaft. That hex nut appears to be stuck, but it's surrounded by a regular standard nut. Just a question: am I supposed to remove the standard nut surrounding the hex or just the hex? I just want to be sure before I go applying pressure to the wrong thing. Attached are some pics for info. I think the hex bolt that I should loosen is shown in the red square in the first pic.
Seems that this should be in the 2-wheel tractor section, so I created a post there. Consider this one dead.
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
2018 SolarTech Silent Messenger Towable Solar Message Board (A64553)
2018 SolarTech...
2011 Kenworth T300 S/A 18ft. Cab and Chassis Truck (A64194)
2011 Kenworth T300...
2016 Ford F-450 Liftmoore 2550 5,000lb. Crane Service Truck (A64556)
2016 Ford F-450...
2022 EZ-GO ELITE...
MILLER BOBCAT 250 PORTABLE ARC WELDER (A64276)
MILLER BOBCAT 250...
