BCS 710 Clutch
   / BCS 710 Clutch #1
53GMC
Bronze Member
Western North Carolina
Ford 8n, Two Massey Ferguson 20 Industrial, Hinomoto
Hello everyone!
I was at the scrap yard the other day when someone brought a bcs 710 tiller in. I asked him what was wrong with it and he said the engine was bad. It was in really good shape so I had to get it:thumbsup: The engine ran pretty good but was a cheap b&s 5hp and still needed more work to be a good engine, so I decided to replace it with a Honda gx200 I had laying around. When I put the engine back on it worked fine for a minute then the clutch would not disengage, I took the engine back off and found the clutch had slid closer to the engine. The set screw was tight. Is there anything to keep the clutch from sliding on the crankshaft? Maybe a bushing:confused: Thanks in advance. Philip.
   / BCS 710 Clutch #2
Hey GMC,
Congratulations on your junkyard find! It always makes me happy to hear someone save good stuff from scrappers. I recently tried to save a bunch of David Bradley stuff from a scrapper, but he took it in anyway. :(
There was a short piece of pipe that slid over the shaft before you slide on the clutch. The 5hp clutch is for a 3/4 inch shaft. Larger HP engines are all 1 inch shafts.
   / BCS 710 Clutch
Bill,
I'll try putting a pipe or bushing on it tomorrow and let you know how it turns out.
Thanks,
Philip.
   / BCS 710 Clutch
The bcs it going great now:thumbsup: I was able to get the clutch adjusted to work with it all the way back on the crankshaft. Now I have a good running bcs with under $150 in it. Thanks for the help, Philip.
   / BCS 710 Clutch #5
That's cool. Great save, and now a great tiller!
2001 DITCH WITCH JT1720 DIRECTIONAL DRILL (A51242)
2001 DITCH WITCH...
2011 L3 GENERATOR SET (A51222)
2011 L3 GENERATOR...
2009 Hyundai Sonata Sedan (A50324)
2009 Hyundai...
Progressive 36ft Mower (A52128)
Progressive 36ft...
2018 CATERPILLAR 308E2 CR EXCAVATOR (A50458)
2018 CATERPILLAR...
vin:16VEX2023H3042174 (A50322)
vin:16VEX2023H30421...
