BB for plowing- Too much stress on 3t hitch
   / BB for plowing- Too much stress on 3t hitch #1
norcalmike
kubota
Hello All,
I have a B7100 with a 3 in 1 Gannon box blade that rotates for ripping, grading and plowing. Today I needed to lower my grade by about 6 inches.
I proceeded to break the ground with the ripper teeth, I think that's what you call them, several times and rotated the blade to plow to move the loose soil while in reverse. This worked better than pulling the soil with the grader as it was able to handle more volume.
My question is am I putting too much stress on the 3pt hitch using the BB as a plow? Is the 3pt hitch designed to be used this way on my B7100? My manual makes no mention of this type of use. As you can tell I am new to tractors.
Thanks,
Mike
B7100DT, FEL, Gannon BB, FL850 tiller
   / BB for plowing- Too much stress on 3t hitch #2
Typical compact tractors are not designed for high reverse loads on the lower links. Either the lower link attachment points break or the lower links themselves bend. Its fine to move loose soil, but hit a immovable or imbeded object and the load can break the typical cast iron (or aluminum in some cases) attachment points. I had a Kubota L48 that had a very sturdy lower link attachment as well as very strudy lower link arms and it was not an issue. I see very few compacts with that type of build design. Rat...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A53472)
LIKE NEW 2023...
2005 Mack CV713 Granite Truck, VIN # 1M2AG11C55M020965 (A51572)
2005 Mack CV713...
NEW Wolverine 72'' Skid Steer Ripper (A53002)
NEW Wolverine 72''...
1997 National RV Tropi-Cal Motorhome (A51694)
1997 National RV...
MacDon C3012F Corn Head (A53342)
MacDon C3012F Corn...
