Batwing cylinder replacement source ? 3" x 14" cylinder
   / Batwing cylinder replacement source ? 3" x 14" cylinder #1
CCOUGHRAN1
A couple of weeks ago I purchased some Rhino Magnum 15 batwing mowers. They had been sitting for some time, and there was some rust and pitting on the exposed wing cylinders. I tried to sand/polish them, but they just had too much pitting, and now they are not holding their position any more.
Looking at the Rhino specs, it says they are a 3x14" with 1.25" shaft. All of my lines are setup for 1/2NPT ports.
I found what appears to be a good replacement cylinder at Surplus Center.
Surplus Center - 3X14X1.25 DA HYD CYL W300140
Is there a better source, or possibly a better cylinder that I need to be looking at?
Thanks,
Chris
Thanks JJ.
   / Batwing cylinder replacement source ? 3" x 14" cylinder #4
I like baileys also for cylinders.
Here is a list of all of their 3x14 cylinders Standard Hydraulic Cylinders
Just double check the lenghts as JJ mentioned, and also make sure the pins are the same diameter.
What type of cylinder is on there now? There are basically only two types, tie-rod and welded. But make sure the ends are the same too, those there are many choices of. IE: Cross-tube, clevis, yoke, etc. Just match it up but you wont find anything much cheaper than baileys.
2015 INTERNATIONAL LF687 (A53843)
2015 INTERNATIONAL...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A51691)
2010 Turfco...
2023 BOBCAT E35 R2 SERIES EXCAVATOR (A52705)
2023 BOBCAT E35 R2...
2012 Club Car Carryall 1 Utility Cart (A54811)
2012 Club Car...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55301)
NEW HOLLAND 706 30...
Utility Trailer (A52377)
Utility Trailer...
