battery
   / battery #1
darrenjttu
Glen Rose, Tx
JD 4300
I need to get a new battery. Is there a special kind of battery for a tractor? Can I just get one with the same specs on it from anywhere?
   / battery #2
I just took my old battery to the local auto parts store and asked for the highest CCA's they have in that size battery.
   / battery #3
First, measure your battery L x W x H. Then check what side the + and - terminals are on. Note the CCA written on the battery.
Then go to a discount place like Sam's Club, Costco (preferred), or Walmart and get the closest thing to the OEM as possible. Costco has the best return/exchange policy in my experience.
   / battery #4
There's no difference in an auto and tractor battery. I do the same as DK35vince - take it out and replace with highest CCA possible that will fit in your space.
   / battery #5
FWIW, I started using a Battery Tender after reading really good reviews on TBN. Since I've only used it for a year or so I can't vouch for it extending the life of the battery, but it sure is nice to know a seldom used machine will crank with a fully charged battery. I expect, too, that battery life will be improved as others have noted.
   / battery #6
We have bought the last couple of batteries for the tractor from Tractor Supply - they seem to have a very good return policy if you have any problems. We found the price to be about the same as elsewhere.
   / battery #7
Don't forget to also check the type of terminal - many are a simple post, but some will have a flattened post with a hole for a bolt, and some industrial machines like skid steers might have a threaded bolt that accepts an eyelet type terminal.
   / battery #8
Not entirely true, there are some differences, sometimes. There’s another thread in process now about the exact same thing. But still, 9 times out of 10 a car battery is just fine.
   / battery #9
Not entirely true, there are some differences, sometimes. There's another thread in process now about the exact same thing. But still, 9 times out of 10 a car battery is just fine.
   / battery #10
Also check that posts of new battery are same orientation (positive on left, negative on right, etc..) as existing battery
Edit: like Dixon already said!
SHOP VAC 6.5HP WET/DRY VAC (A51248)
SHOP VAC 6.5HP...
43029 (A51691)
43029 (A51691)
2004 Lull 944E-42 Telescopic Forklift (A53117)
2004 Lull 944E-42...
SENTRY 100 STATIC GUARD (A51248)
SENTRY 100 STATIC...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
SYSTEM ONE 102 DEGREES PARTS WASHER (A51248)
SYSTEM ONE 102...
