battery terminals reversed?
   / battery terminals reversed? #1
Roots
JD 750 MFWD
New to me JD750. Bought over summer and used a couple of times to mow.
Tractor had been sitting in garage for a couple of months since last use. I've been trying to get it ready for winter, starting with lights (none worked when I bought it). Now have panel indicator lights, tail lamp and rear flood, but no headlights or warning lamps (more on this in a later post).
When I got done playing with lights, I decided to start the tractor. Tractor would not start. Had been starting on first or second try up to this point. Checked all fluids. All appear ok. Weather has gotten colder, barely freezing on a few nights, but 50-60's during day. Added anti-gel to fule tank (I know, if it's gelled in lines, too late now, but better than none). Decided battery was too weak to turn starter (starting circuit buzzed, but starter did not crank on key, battery voltage 11.4V).
When I decided to try to boost, got a surprise; battery appeared to be in reverse orientation (neg (-) post of battery connected to red pos (+) terminal lead, pos (+) post of battery connected to black neg terminal lead)?!
I looked through owner's manual and service manual, but could find no apparent reason to switch battery leads...
Bought tractor from reseller, who bought it at auction in upstate NY. Little history on past owner.
Bought a replacement group 24 850CCA battery at Wal-Mart, but have yet to connect it.
Some questions following this "discovery";
1. Is it possible that previous owner decided to switch terminals to reverse the ground from (-) ground to (+) ground? For what reason?
2. If so, is it possible that additional modifications were performed for electrical system to operate on (+) ground, and that I might do damage by connecting new battery in "correct" position / (-) ground?
3. What damage can arise from connecting battery in reverse, as done above?
4. Is it possible that remaining nonfunctional lights are from connecting battery in reverse orientation?
Thanks, Eric.
   / battery terminals reversed? #2
The older tractors did use reverse polarity.
I have never had a problem switching the polarity to a neg ground.
   / battery terminals reversed? #3
1. possible, but idiotic. that would essentially switch the electrical system from a negative ground system to a positive ground system. The wiring's just not set up that way.
2. unlikely and unlikely
3. probably none. and I suspect it might fix the instrumentation/lighting issue too.
4. see #3 above
//greg//
   / battery terminals reversed? #4
All of the online wiring diagrams, which I looked at, indicate a negative ground. Make sure the red wire goes where it should and the black wire goes to ground. (They could be swapped on the other end, from the battery. So "color" wouldn't mean anything)
The other thing, the original battery could be mis-labeled. You should check that with a meter.
Good point on color of leads. It was too dark to see last night, but on checking today, it seems that red lead goes to ground on chassis, and black lead goes to alt. I guess this means red lead=neg ground, so connect to neg battery post. Wonder why factory or previous owner didn't use correct color leads? Doesn't help with the nonfunctional lights, so search gows on for those...
   / battery terminals reversed? #7
Don't go by color alone, check the battery for plus/minus marks and/or use a volt meter.
   / battery terminals reversed? #8
With a change like that, anything is possible from the past. At some point, the system could have been reverse polarized. .. and then wires moved here and there, to "just get it to work".
I'd get the black and red changed to correct position, for a start.
   / battery terminals reversed? #9
It's like, you "read my mind"! .. or earlier post.
2015 Ford F450 SD Flatbed (A52377)
2015 Ford F450 SD...
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A52141)
2006 KENWORTH T800...
2019 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A54607)
2019 FREIGHTLINER...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
Caterpillar 56in Excavator Bucket (A51691)
Caterpillar 56in...
