Battery removal on a LK3054
   / Battery removal on a LK3054 #1
osumason
Oklahoma
Branson 2400
I to replace my battery, but not sure how to remove it. The steel bracket that the air cleaner sits above the battery and doesn't come out. The only other option is out front but do you really have to remove all the brackets and screws from the grill and remove that whole assembly??:mad::mad:
TIA
   / Battery removal on a LK3054 #2
Nothing in the manual?
Can you post a picture? May help to figure it out. Usually the battery area is pretty open and accessible.
   / Battery removal on a LK3054 #3
Need to remove out the front. Pull brush guard forward and remove wing nuts holding the front grill in and remove the grill. Can’t remember if there’s other attach point for grill it’s been a while. Not overly difficult.
   / Battery removal on a LK3054 #4
Just the 2 bolts at the bottom of the grill, then lower grill to clear the upper pins and remove. Remove the battery hold down and slide it out. A pain, but not horrible!
2015 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2015 Ford F-250...
2015 Ford Fusion S Sedan (A51694)
2015 Ford Fusion S...
Pickup Truck Bed (A51691)
Pickup Truck Bed...
1998 JCB 930 (A50120)
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
KJ 20'x12' Livestock Metal Shed (A50121)
KJ 20'x12'...
