Battery (or starting) Problem
   / Battery (or starting) Problem #1
HillStreet
Veteran Member
Maine
Kubota B2650HST. Kubota Z125S
Hey Everybody:
This concerns my Kubota zero turn which is idle in the shed during the winter. Instead of leaving well enough alone, I just had to screw it up. I wanted to install electrical extensions from the battery to a convenient spot on the frame so I can hook up the BatteryMinder (maybe BatteryTender). I fully charged the battery before connecting the battery and my extension痴 ring terminals. Volt meter said 13.4 volts with no load.
Then I sit in the seat to start and it just GROANS when I turn the key. This groaning sound drops right off, then repeats when I turn the key off then on again. I don稚 know, what may be going on?
   / Battery (or starting) Problem #2
Volts are one thing... what are the Amps? It's the Amps that provide the 'Ooomph' to initially start/turn-over the engine.
Your charger will indicate a full charge (Volts). I leave the charger on for a few more hours to increase the Amps.
   / Battery (or starting) Problem #3
Is the battery frozen...how old the battery.
Bring the battery inside for winter storage???
It has been on the mower out in the shed. When I disconnected it to install the BatteryTender extension with the battery rings I did the charge with my other charger for 36 hours or so. It was 40 degrees today but of course the cold sink is way low. The machine was new in June 2016.
   / Battery (or starting) Problem #5
Get the polarity right when reconnecting?.... Just adding extensions should not effect how battery actually operates starter and ignition... Battery could be toast....
Take battery to a O'Rileys or "other " auto parts store and have it tested..... Most of the new batteries made in last five years are really lucky to last 3 years any more....
Dale
And how can I check the amps in that there ooomph?
Get the polarity right when reconnecting?.... Just adding extensions should not effect how battery actually operates starter and ignition... Battery could be toast.... Let it sit on low charge rate for 24 hours and try again....
Dale
Yeah polarity is good. I know the ring terminals are not the issue but was just explaining the procedure that got us here. Also, I should note I drove it into the shed when I put it away in November.
   / Battery (or starting) Problem #9
Your mower likely came with a Deka 51r battery, which is a quality battery. It takes very little resistance at the battery terminals to create a no start condition. If you removed or loosened the terminals when installing your external charger terminals I would recommend you remove, clean and reattach the battery cables.
Other areas of poor connections are the ground straps to frame, and the front surface of the starter itself.
   / Battery (or starting) Problem #10
Electrical trouble shooting 101: Start with a known good battery. The best way to determine if your battery is good is pull it and fully charge it. Then take it to your local big box auto parts emporium and have it load tested for free.
2020 Kia Soul (A52377)
2011 Ford F-550 Iowa 1015 3,200LB Crane Mechanics Truck (A51692)
2011 Ford F-550...
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
Duetz Power Unit (A50120)
Duetz Power Unit...
Ford Super Duty FX4 Pickup Truck Bed (A51691)
Ford Super Duty...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
