Battery maintenance
/ Battery maintenance #1
canadakubota
1000 Is Pkwy, SouthEastern Ontario, Canada
Kubota B2620
Hello TBN members'
I am wondering your opinions regarding battery blankets.
I am considering installing one on my Kubota B2620.
I have a 1999 Kodiak ATV with the original battery. The ATV has approx 4550 kms. I also use the battery to start a portable 6500 watt generator.
Each winter when not operating the ATV or generator, I bring the battery inside a heated shop, connect to a 1 amp charger for a day and store on a dry rubber mat.
Battery blanket?
Just a lucky ATV battery?
Thank you in advance for any input/suggestions.
/ Battery maintenance #2
Well, my tractor battery is 11 - 12 years old. I just make sure the water level is right and, if it will be left unused for more than a month, I put a float charger on it to maintain the charge. Cold does not harm a battery, it discharges slower than in warm temperatures. The best advice is to make sure the battery is fully charged.
/ Battery maintenance #3
Hello TBN members'
Battery blanket?
http://www.tractorbynet.com/forums/owning-operating/189488-battey-tenders-do-they-discharge.html
/ Battery maintenance #4
I tried various things on the battery for my generator. The thing that works is a battery tender. It's outside now with a cover over the generator and the battery tender connected to the battery.
It used to be basically outside, but with the breakfast room as a cover above it. I figured this was not safe; so, its now moved to behind the carriage house. Had to have a new generator feed line, etc. to relocate it. The tender was used for about 5 years in the old location.
Ralph
/ Battery maintenance #5
Rather than start another thread, the title of this one works nicely, though maybe not along the same line as the original post.
I have a JLG T350 boom lift. Hydraulics powered by 4 6 volt batteries. I've removed them for the winter and brought them into my attached garage. I plan on keeping them up with a battery tender. Is there a need to loosen the battery caps?
All other batteries that I use the tender on (2 Harleys and a Mustang GT) are sealed so it isn't an issue. These are the first batteries with removable caps that I've had in many a year.
/ Battery maintenance #6
No, for the current involved, the built-in vents are sufficient.
Very good. Thanks for the info. Only problem now is one tender and 7 batteries!
I guess I could just move it to a different battery every day of the week. :laughing:
/ Battery maintenance #7
I use 7 different singles throughout the garage. Or you can buy a 4-banger to share.
/ Battery maintenance #9
I just rotate my battery tender amongst 3 bikes, 1 tractor, 1 plow truck. The bikes & tractor only get charged a few times a winter. The plow truck before every snow as it's a hard starting POS.
I got 7 years out of an OEM bike battery that way. Battery never left the bike. Bike is/was stored in unheated shed. It doesn't take a whole lot to maintain a battery IMHO.
/ Battery maintenance #10
Too much of a pain running extension cords or pushing two bikes (up on rolling motorcycle jacks) to the power.
The boom lift batteries (4) will stay in one spot with a dedicated tender. I think I'll just remove the bike and car batteries and line them up on a work bench and alternate every couple of days with a second tender. Looks like the local NAPA will get back some store credit that they owe me today!
/ Battery maintenance #11
I check my boat batteries about every 3 months by hooking the charger to them. Most of the time they show fully charged and that is without a tender. We dont have subzero temps here but it seems to work ok like that. Without any electronics draining the battery, they should stay charged a long time.
/ Battery maintenance #12
Keeping the battery charged is very good advice. A battery "tender" or "maintainer" usually means it has some more advanced circuitry that adjusts the small charge to the state of the battery. A "trickle" charger usually means it keeps charging at a trickle, no matter what the state of the battery.
If you decide to use a battery blanket, a good accessory would be a plug-in thermostat such as the DuroStat. It is waterproof for outdoor use, will handle 2,000 watts, and you can adjust the temperature setting. Otherwise, the blanket will be heating 24/7, and your electric bill will be higher than it needs to be.
/ Battery maintenance #13
Only problem with that is with us retired folks, we forget what day of the week it is. :)
So I said the heck with it and picked up a 6/12 volt tender yesterday to dedicate to the (4) six volt batteries of the boom lift.
The bike/Mustang/mower batteries will be lined up on a bench for the other tender.
Someday I'll get to be a retiree! :thumbsup:
/ Battery maintenance #14
Cold weather won't hurt a battery IF ITS FULLY CHARGED. If not it can freeze. Which WILL hurt it.
Sitting on a cement floor won't hurt a battery, but acid leakage WILL hurt the floor.....and a battery up off the floor will warm up faster if you are heating the room/shop
Cold temperature WILL reduce the output of a battery.
I have my battery heater on the same cord as my block heaters, plus its next to the radiator, so a warm rad = a warm battery
3143 (A63117)
3143 (A63117)
JOHN DEERE 8360R TRACTOR (A64278)
JOHN DEERE 8360R...
2018 JOHN DEERE 35G EXCAVATOR (A65053)
2018 JOHN DEERE...
2004 Mack 613 Concrete Mixing Truck (A64194)
2004 Mack 613...
2025 Auger Bit Skid Steer Attachment (A64553)
2025 Auger Bit...
PALLET OF STAINLESS STEEL FEEDERS & WATERERS (A64278)
PALLET OF...
