Battery LS XR4040
   / Battery LS XR4040 #1
Kc8ehd
Hinton Wv
LS XR4040C
any one have a cross for the battery that came in this tractor ? (XR4040C) peferable EXIDE OR iNTERSTATE
   / Battery LS XR4040 #2
Do you happen to know the make and model of the one that is currently on your tractor? That would make cross referencing a lot easier.
   / Battery LS XR4040 #4
You can just take it to the parts store and match it up get the most cca .You will have to bring the old one back any ways, core charge make one trip ,Get some anti corrosion washer to
   / Battery LS XR4040
Didn't recognize the brand , checked my service manual ...calls for group 34 660 cca
The battery that's in it starts fine at temperature above 32 F
At colder temperature it just clicks ...2nd battery with only 48 hours ,dealer replaced with same type of battery as well as a new starter ...starts fine instill it gets cold than 32F have to jump start it ..., starts easy with jumper. Thinking these off brand battery just won't handle the cold , going to try a 800cca and see what happens...
S
   / Battery LS XR4040 #6
advanced auto parts $94 with 25%off coupon
AutoCraft Silver Battery, Group Size 34/78, 800 CCA
   / Battery LS XR4040 #7
Tractor Supply 402005299, Exide 770 CCA, $99.99
   / Battery LS XR4040 #8
New Holland BNH34770W, OEM, CCA 770, $118.50. This is the same battery used on the NH badged version of the LS.
   / Battery LS XR4040
went with NAPA# 8434 group 34 battery (800cca) , due for more cold weather this coming week we will see if the battery was the cause of the cold weather non starting issues
the battery I removed from had no ratings listed in English , battery tester showed 560cca at 30 degree
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
Portable Calf Creep Feeder (A50515)
Portable Calf...
Tallman Water Pump (A50774)
Tallman Water Pump...
2014 FORD F-350 SUPER DUTY CREW CAB FLATBED TRUCK (A51243)
2014 FORD F-350...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
TRAILER AXLE (A51244)
