JDTank
Platinum Member
- Joined
- Oct 5, 2010
- Messages
- 693
In-Laws have an old 19.5 HP B&S Turbocool riding mower with a 42 inch deck.
Just recently it has started to die overnight. You boost it the next day, cut your grass, and if you stop it and restart it within a few hours, if your doing random work, it will start because the charge is still there.
I tested for a parasitic draw this afternoon. It came back with 0.03 MA. Is this enough to drain the battery? My thinking is there shouldn't be ANY draw because it's a riding mower. It doesn't have a radio clock or security system like cars do that need constant power to remember settings. It only has the front lights which I wired on a new circuit and switch myself 2 months ago, because the terminal for lights on the factory key switch is dead, must have broken inside. I already checked my circuit I made for the lights and it is not the issue. I get the same parasitic draw with my circuit hooked up and disconnected.
I noticed there are two wires running to the front of the engine by the carb. I know it has a vacuum fuel pump so what could this be? Solenoid? I haven't checked these yet because I forgot to, and the weather has turned severe here, warnings in place! :dance1:
My guess is the key switch must be drawing power.
Can I replace it with just any car key ignition switch from a hardware store? Does it HAVE to be a craftsman switch? I know my local Canadian Tire sells ignitions with 5, 6, 7, even 8 terminals, including two keys, meant for older cars. I figured I could just buy one of those and pop it in there.
Thanks for the help!
