90cummins
Veteran Member
Earlier I started a thread titled (SolarCity installing a 6.37kw system on my house!!!)
This new thread is to discuss a Battery back-up System to complement my new Solarcity system.
At this point in time any battery back-up system I may install is not compatible with my Solarcity system primarily because of warranty issues. They will not repair the system if they (find or think) my system may have caused the failure.
So this system will be separate from the Solarcity/grid side and connected to the generator side of my auto transfer switch.
I'm currently looking into a 6kw battery backup system to supplement my new Solarcity system with perhaps 12 hours of autonomy so an outage will not disrupt my routine.
I have gasoline & diesel generators (120/240 volt) for back-up and battery charging purposes but I have been thinking about using a brushless Niehoff 24v 300 amp generator to recharge the batteries and support my battery backup system for prolonged periods.
The reasoning for my consideration of DC is this;
AC generation requires 1800 or 3600 rpm, a DC generator on the other hand requires only enough speed & hp to excite the field to start production and meet the demand load.
This allows fuel savings because the engine may be operated much slower speed for fuel savings, extended life and less noise. The generator voltage is self-regulating and eliminates the inefficiency of creating AC power at 3600 rpm to operate an AC powered charge controller to produce DC power for battery charging purposes.
24v DC generators are simple and cheap to acquire and are easily adapted because of the belt drive.
A 300 amp generator will produce 200A at 24v (4800w) at 2000 rpm generator shaft speed.
The sweet spot for fuel efficiency for a 9 or 10hp Yanmar diesel is 2500 to 3000 rpm at which speed a Yanmar L90 and L100 produce 5.5 and 6.2kw respectively.
At 2250 rpm both Yanmar痴 produce close to 5kw. Based on the output curve of both the generator and engine a direct drive or 1 to 1 ratio would work.
Any thoughts on my plans are welcome.
At this point in time I have the following in place to support myself during a power outage.
1) 6.7hp Yanmar diesel 5kw generator 120/240v
1) Rebuilt Yanmar L90 Diesel with tapered crankshaft.
1) Rebuilt Yanmar L100 Diesel with tapered crankshaft
2) Generac XL4000 generators
1) 25kw PTO generator
1) Rebuilt 6kw Silent Chinese diesel generator which is for sale.
1) 3kw Yanmar generator not running.
Planning on purchasing an 24v AIMs 6kw split phase pure sine inverter/charger.
90cummins
90cummins
