Basic Starting Issues
   / Basic Starting Issues #1
futuorganics
I have a basic question. I am having some trouble starting my 2210D. In simple terms it cranks but doesn't turn over. It has been sitting for approximately 2 years (lol). I replaced the ignition switch. Checked the air filter. Cleaned out the fuel filter. Bled the fuel line but still no luck. It sounds as if it wants to start but I don't want to burn up my new switch or starter constantly cranking it. Any suggestions?????
   / Basic Starting Issues #2
Check to see if there is any stoppage in the muffler. Check fuel at injectors. check your fuel lines . Fuel lines will go bad & close up on the inside. These may be the original fuel lines & return lines
   / Basic Starting Issues #3
Kenmac is giving you good advice. In case you don't fully understand what he is saying:
Make sure the muffler isn't plugged with mud, nesting material, a potatoe or whatever. Have someone turn over the engine and hold your hand over it to see if the engine has compression.
Take a wrench and crack open the line at each injector just lightly to see if fuel is getting to them when you turn it over. (This can spray fuel out around the line / nut - wear eye protection). If a good spray isn't coming out, you have air in your lines. When you have steady fuel with no bubbles, tighten up the nuts again and try again. This is an easy and effective way to bleed air from your fuel system. (I know, it can also be environmentally irresponsible and can make a mess, but it's my preferred tactic).
Other possibilities if you change out your old fuel lines:
Pull the valve cover off and insure none of the valves are stuck open. Although two years isn't excessive, it can happen.
Not familiar with your model, but just in case you have a solenoid shutdown, make sure it opens when you turn the key on.
Make sure the throttle is set properly for start and that the linkage is working to the fuel pump.
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2001 Ford Ranger Pickup Truck (A51694)
2001 Ford Ranger...
2022 Tracker Pro Team 190 TX Tournament Edition Ba (A53117)
2022 Tracker Pro...
2018 Jeep Grand Cherokee SUV (A51694)
2018 Jeep Grand...
2021 Top Hat Bumper Pull Equipment Trailer (A53117)
2021 Top Hat...
2010 Ford Escape Hybrid SUV (A51694)
2010 Ford Escape...
