I am considering the purchase of a 25-35 HP tractor for mainly landscaping a slightly sloped 3.3 acres. I have a few rookie questions on hydraulics.
Most tractors and skid steers spec hydraulic pump flow rate but not psi. It strikes me that the psi that a hydraulic pump can generate is also very important. Yet I cannot seem to find any specs on psi.
It is my understanding that flow rate determines the speed of an implement (FEL for example), but wouldn't psi along with cylinder diameter determine "IF" a given load can be lifted at all ?
The bigger the cylinder the slower it moves (assuming constant flow rate) but the less psi required to lift a given load? yes?
Is there a standard psi (perhaps 2500 psi) that pumps generate and what seperates small from big is the flow rate? Which is then matched to cylinder size to give a reasonable lift rate and of course the cylinder diameter and/or relief valve would be sized so as not to cause any of the steel involved (bucket, lift arms etc...) to break?
Do most implements (FEL for example) have built in releif valves? Preventing the pressure from getting too high?
Thanks for listening,
Tim
Tim
