N80
Super Member
Need advice on a basement dehumidifier. It is a mostly unfinished basement, 85 year old house, probably 900-1000 sq ft, concrete floors. It leaks. Water oozes in from the foundation walls but only with heavy rains. No sump at this time because there is not a single low spot to accommodate one. Only the front and sides are below grade so no seepage on the back side. Solving the problem is going to require digging all around front and sides of house and coating foundation walls. Do not have the money for that right now. After heavy rains I probably remove 20 gallons of water off the floor with the shop vac. Usually less.
So, I will make some stop gap changes to help control seepage but it is still too damp down there. My tools get a skim of rust on them, etc. However, no mold or dampness on floor joists. Anyway, I think a heavy duty dehumidifier might be in order. It will need to have a condensate pump or accommodations to fit one. I know these things can be pricey and I hear the ones from the big box stores don't last very long. So I'm looking for recommendations and any experience you guys may have with these. Thanks.
