barnes/haldex question
   / barnes/haldex question #1
rbushmaster
my 22 gpm barnes 2 stage pump came today from Northern {with no literature] cant even find any online found drawings but thats it
can the pump be reclocked
if i take out the 4 bolts that hold pump together can i turn the mounting flange so it will position the inlet and outlet in a better spot?
and if so is anything going to come flying out? like little springs , check balls etc?
thanks
   / barnes/haldex question #2
I would not untorque this pump under any circumstances......these small pumps have thin clear cellophane gaskets between the sections.....once disturbed they may not go back together with the same results......other pumps can be reclocked relatively easy.....but not Barnes/Haldex....
These pumps being smaller operate under tighter tolerances than their big brothers.....Again, Don't do it.....Buy the fittings to make it work with what you have....:thumbsup:
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2011 John Deere 5075 4WD Agricultural Tractor (A52377)
2011 John Deere...
2005 KOMATSU PC400LC-7L EXCAVATOR (A51246)
2005 KOMATSU...
Yale GLC050LXNVAE087 5,000lbs Propane Cushion Tire Forklift (A51691)
Yale...
2017 Kubota KX080-4 Mini Excavator (A51573)
2017 Kubota...
