barn roof leaks
   / barn roof leaks #1
heehaw
Veteran Member
russellville, arkansas
Kubota M4900, B7510 and RTV
i had a 30x50 barn built a few years ago: an for the first time, i was in it with it really raining hard last week: the whole west end leaked: i climbed up on it yesterday an saw right off why: the last piece of sheet metal was cut off, just before the high ridge: an the end trim had a gap anywhere from 1/4 to 1/2 inch: so the last 8-12 inches of the roof tin, was just acting like a funnel to put the water right under the trim an into the barn: i went to lowes to get some "kool seal" to fix this: now get your calculator out: a gallon of kool seal is $9.98 or you can pay $64 an get 4.75 gallons: i picked up a couple gallons an some nylon reinforcement that you lay in the stuff to strength it an help it bridge the gaps: now the roof shouldn't be leaking any more.. i probably could have caulked it, but i have used this stuff several times over the years on trailer roof leaks an it seems to really work well.
heehaw
   / barn roof leaks #2
Would that be a redneck discount for bulk?:rolleyes::rolleyes:
   / barn roof leaks
you know bulk prices are always cheaper..or so many think..
heehaw
   / barn roof leaks #5
For small leaks I use the white caulking for gutter (whatever its called). Great stuff!
2017 Ford Transit 350 Handicapped Van (A55788)
2017 Ford Transit...
2006 MAC TRAILER MANUFACTURING (A55788)
2006 MAC TRAILER...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2014 FREIGHTLINER 114SD VACUUM TRUCK (A51406)
2014 FREIGHTLINER...
CHINESE 125 ATV (A54756)
CHINESE 125 ATV...
2022 Ford Escape S AWD SUV (A55853)
2022 Ford Escape S...
