Barbwire fence wood posts or tposts?
   / Barbwire fence wood posts or tposts? #1
TxJack
Houston, TX
:confused:
Is a tpost "only" run for a barbwire fence strong enough or is it better to have a wood post after every couple of tposts? The pressure treated posts these days just seem brittle and don't seem to last.
   / Barbwire fence wood posts or tposts? #2
I like to use both. I usually have 3-4 T-posts between the wooden posts, as well as either wooden corners and "H" in the line. I like wooden posts, but there is always the fire risk, especially in the areas still in a drought. If you want to avoid wood altogether, you could use pipe in place of it, and still be cheaper using T-posts than if it were all pipe.
   / Barbwire fence wood posts or tposts? #3
a lot depends on soil conditions and how the t post stand up, I use the heaver T posts,
I have been building my newer fences out of both,
one wood post and 4 Tee posts, one wood, 4 tee,
the old fence is all most 100% wood, a tee post about ever 20 or 30 to drain or ground out lighting strikes, save having to go and replace 10 or so splintered posts after a storm, and have not had any cattle hurt since adding the steel post to the fence.
yes I agree the new wood posts seem very weak, and snap easily,
I use 4-5" wood posts, normally the deal is (at least last year) the cost difference was only 50 cents or so, the work of putting them in is part of my consideration, (they seem a little harder ever year now).
we have over 10 miles of fence to keep up, I need to rebuild a mile and half this summer some time, two fences that are seldom used, and about 50% of the posts are in need of replacement,
and I have a bunch of corners to build or rebuild as well,
I am considering trying some different on the corners, and that is to about 100 to 150 feet out from the corner start to bring the wire down to near the base of the post, so the stretched wire has less leverage to work the corners back up out of the ground, and then use a "short" wire to fill in the fence where they should be, in that 150 or so feet, in this sand in 10 to 15 years the corners start to lift out,
I guess I could bolt on some steel wings to the base of the posts so they would help anchor them, and still use the post driver, (post driver new), in the past they were all hand dug holes, and most were over 3 feet deep usually use 8" round posts on the corners,
   / Barbwire fence wood posts or tposts? #4
:confused:
i do wood corners with angle or H braces at the corner.. then H braces on spans. with tpost the rest of the uprights. Gate posts are trreated like corners.
wood posts get staples. tpost wire clips. both have their plusses.
In my area.. tpost are cheaper and weasier to install, and remove.
   / Barbwire fence wood posts or tposts? #5
+1 I do like Soundguy and use a Rohrer t-post driver works well even in the rocky soil around here. :thumbsup: I have found that my hands no longer fit around a post hole digger! :D
   / Barbwire fence wood posts or tposts? #6
   / Barbwire fence wood posts or tposts? #7
20 or so years ago I used a mix of treated posts with several T posts between. As problems arose with the wood posts...rotted, pulled out of the ground...I replaced with T posts. I recommend T posts now with concrete or welded pipe end/corner posts.
Now, I use T posts exclusively. I drive them using my FEL with a pipe sheath on the full length of the T post to prevent it from bending under pressure. HST provides the precision movement needed for safety and driving accuracy.
   / Barbwire fence wood posts or tposts? #8
I have a mile and a half of barb wire fence around my 80 acres. I still have about 20-30 wooden posts because I just haven't got around to jack hammering a hole in the bedrock to set a T-post. The "wooden post" is a post with a cross piece on the bottom to hold it upright - it doesn't go into the ground because it sits directly on exposed basaltic lava bedrock. About 20% of all my T-posts are set in very solid bedrock. I've never had a range fire started by a lightning strike on my fence line although I've seen them and they can be devastating. My corners are metal gabions 4'x4'x4' filled with rock. My home made T-post pounder is a chunk of 4" well pipe with a 40lb steel chunk welded on one end. Its a little clunky getting the pounder "loaded" and upright but MAN does it do the job.
   / Barbwire fence wood posts or tposts? #9
The OP didn't specify what he is fencing in. AFAIK, cattle tend to push against fences more than horses and that makes a difference in post selection.
   / Barbwire fence wood posts or tposts? #10
I fenced for cattle, 5-6 strands barbed wire, and use a hot wire about nose (theirs) high to keep them off it; battery operated.
I live on Houston Black Clay that has a tremendous volumetric variation from winter to summer. As a result T posts just fall through the cracks in the summer requiring the periodic tensioners to keep them up. I started out 35 years ago with wood for corners and periodic tensioners. Today they are 2 3/8 Sch 40 pipe sitting in 12" x 3' concrete holes. H braces at about 600' and intermediate single poles at about 60'. All corners are double braced at 8' widths....a corner would have 5 posts. Now that I can afford a portable welder, the pipe is easier to work, no cross brace wire to fool with and no rot. I paint them "Natures Brown" which works great....zero maintenance for me.
Mark
BUSH HOG 2615 - 15' BATWING MOWER (A51243)
BUSH HOG 2615 -...
2011 Retesa CT7622 150 Tri-Axle Vacuum Tanker Trailer (A52377)
2011 Retesa CT7622...
Titan PDG3200 Gas Powered Post Driver (A52377)
Titan PDG3200 Gas...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
UNUSED LANDHONOR 82" FORK EXTENSIONS (A54757)
UNUSED LANDHONOR...
2018 WACKER NEUSON RTSC3 ROLLER (A53426)
2018 WACKER NEUSON...
