Barbed wure removal problem
   / Barbed wure removal problem #1
63DH8
Parkland,Washington State, U.S.A.
Massey Ferguson GC1725M Bolens TX 1504 (G154) 1957 John Deere 420C crawler
Almost 30 years ago, I put a barbed wire fence up around my parent's property. Since then, the posts have fallen and the field has overgrown. I had almost forgotten about the fence until my tractor's brushhog found some. What I'm trying to figure out is how to find and remove the barbed wire from the field. Would a rock rake work? What else could I use to find and remove the barbed wire?
   / Barbed wure removal problem #2
Maybe something like this will work for you. Gerard
   / Barbed wure removal problem #3
You could spray the general area with Roundup, and then when all is dead and dry, burn it. By doing it this way no vegetation gets entangled in the barbwire and it will be easy to handle.
   / Barbed wure removal problem #4
The rake should help locate the wire. Removing it may be another factor. Chances are there will be a lot of hand work after you locate the wire.
Egon
   / Barbed wure removal problem #5
What Egon said.
And the rolls seem to be a lot bigger then when they were installed. I think the wire when it gets exposed to air, triples in length. /forums/images/graemlins/grin.gif
Wear good gloves, eye protection and raggy clothes when your picking it up. Good luck.
-Mike Z. /forums/images/graemlins/grin.gif
   / Barbed wure removal problem #6
Neighbor kids, cash, food, cutting pliers.
I have never used or seen a easy way to remove barded wire.
Start at one end and roll it onto a 5 gallon bucket until you run out of room, then get another bucket. Go to the phone company and see if you can get some small wire spools.
   / Barbed wure removal problem #7
Get a tetnus shot before you start messing with the wire. If you have lots to remove, you are sure to get a few punctures...
   / Barbed wure removal problem #9
Find an end and begin pulling up. This is WORK. Some way to apply power to the pull will help a bunch. The idea of burning off before beginning will also facilitate progress. You will probably have to pull staples from each post.
Harry K
   / Barbed wure removal problem #10
The best thing I ever seen was a guy with a bulldozer cleared a fence line,posts, wire and all . He dropped the blade followed the fence line and pushed it all in a pile shoved the dirt/wire over in a ravine and I had a nice clean piece of ground to work on.No brush,no posts,no wire.
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2010 International Prostar (A47477)
2010 International...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
23169 (A50324)
23169 (A50324)
2011 Ford Explorer SUV (A53424)
2011 Ford Explorer...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
