Barbed Wire Fence Unroller
   / Barbed Wire Fence Unroller #1
bmaverick
Super Member
Beloit-WI
Yanmar YM2610 ■YANMAR GURU■ EXTRAORDINAIRE
This is tooooo good not to share.
I hang out on HomemadeTools.net - Encyclopedia of Homemade Tools and Imabass just made a DIY Barbed Wire Fence Unroller that is by far better than the Co-op or Tractor Supply offers! Yet it's very simple to make from welding or wood or thick PVC.
I'll be making mine from PVC that fits on my box-blade. Needing 2 barb-wire spoolers and 1 hot-wire spool.
Here's his blurb ... :thumbsup:
I built this a few months ago. I have modified it from the one in the video by adding 2 additional arms so I can unroll all 6 wires on my fence at once. Each roller is adjustable to accommodate all the standard rolls of wire. This worked great as I was able to unroll all the wires at once and keep them from tangling up. I have tons of fencing to redo and this will be an amazing time saver. It is really doable as a one man team and really speeds up the process.
Basic materials list:
1' of 2x2 square tubing for the receive tube mount.
4' of 2-3/8 oil field pipe for the main mast.
6- 6" pieces of 2-7/8 oil field pipe to swivel around the 2-3/8 pipe.
6- 14" pieces of 1x1.5 tubing for the swing arms. These are welded to the 2/7-8 swivels.
6- 12" pieces of 1" round tubing for the rolls of wire to rotate on.
6- 1" fender washers. I added these from the video posted. These are welded about 2" above the arms and the rolls of wire rest on them.
This was mostly all scrap metal that I had laying around.
There are some wire roller trailers out there that sell for $150ish and only unroll 1 strand at a time. I don't have that kind of spare time to use something like that.
   / Barbed Wire Fence Unroller #2
I watched some of the video, but don’t have sound. Did he mention being able to go over .1 mph? I was waiting to see what happened when he drove at a “normal” speed. I built a contraption to layout 3 at a time this fall, and the way barbed wire unrolls, unless he has some sort of tensioners for each roll I promise it’s getting tangled. I built mine so the rolls are horizontal to help minimize tangling, but I can’t say it helped much. I spent enough time untangling the wires that it was almost as fast to just roll out 2 at a time, though not quite.
BTW, I wouldn’t suggest trying one out of wood or PVC. There’s a lot of pressure once you get moving, especially when built vertically like that one is.
   / Barbed Wire Fence Unroller #3
To save fabrication effort get a piece of 1/2" water pipe about 4' long and run it thru the lift arm balls with 2 rolls between the arms and one outside.
   / Barbed Wire Fence Unroller #4
My dad made one out of the handle of on old push mower. Ran a rod between the ends and put a dick of mild steel tight to each end. Worked well and it did not tangle often, and was not hard to stop when it did. Ed
   / Barbed Wire Fence Unroller #5
When I installed the barbed wire fence around my 80 acres - I did one strand at a time. Its hard enough keeping one strand from not catching on stuff, binding up, snarling etc,etc. I can not imagine doing four at a time and I would NEVER ask anybody to "tend" the barbed wire as it unwinds and you lay it with the tractor. I put a heavy bar between the upper arms of the 3-point, put the spool of wire on the bar and laid it out with the tractor.
During one run I had the wire hang up and when I released the tension - the wire recoiled back and cleared almost a quarter acre of sage brush.
   / Barbed Wire Fence Unroller #6
Sorry, I get up early and don't turn on the lights and my hunt and peck don't always turn out as planed. Ed
2019 John Deere 8270R Tractor  Duals, GPS Ready, 8039 Hours  Field Proven and Work Ready (A44789)
2019 John Deere...
2017 FREIGHTLINER CASCADIA (A45046)
2017 FREIGHTLINER...
2019 Ford F-150 (A41519)
2019 Ford F-150...
CONTAINER  SKID (A45046)
CONTAINER SKID...
2015 WESTERN STAR 4900 TRI AXLE (A45046)
2015 WESTERN STAR...
More info coming soon! (A44571)
More info coming...
