Bar Length Recommendations
   / Bar Length Recommendations #1
Famah
Bronze Member
Wilmot, NH
2010 Kubota L3700SU
Greetings Learned Forum:
After a fair amount of reading, listening and considering, I have decided to buy a Husqvarna 346XP. My use is about 80% small stuff, with the occasional big tree. The saw is sold with an 18" bar. My dealer indicated that he might be able to throw in an extra bar. I was wondering, given this particular saw:
1. Would it be useful to have more than one size bar?
2. If no, what would be the best compromise all around bar size?
3. If yes, what 2 bar sizes would be the most useful to have?
As always, thank you for your thoughts and opinions. They are greatly appreciated.
Nick
   / Bar Length Recommendations #2
I run an 18" bar on my husky:thumbsup: and have taken down some pretty big trees 2' diameter plus. A 24" bar would have been nice and IF I would get another bar that would be it. You also have to bend over less with a longer bar. So for me the 18" is the best all around, 24" is the one I would want for a second.
   / Bar Length Recommendations #3
A 24" bar is a little too much bar for that saw IMO, if you are doing cutting that actualy requires that sized bar. If only to extend your reach, but still only cut smaller stuff, thats different.
A 20" bar would work but not a lot of difference than the 18. I wouldn't go smaller at all. Only advantage is weight savings and a little cheaper on replacements, but both are minimal.
If it were mine, I'd just get the two 18" bars and make sure they take the same drive link guage. That way, there is never any confusion and all the bars and chains you have can be mixed and matched. And there will only be one size to remember when having to get replacemet chain.
But another consideration, get one bar/chain combo with square back (chisel) chain and a sprocket nose. Use this for cutting green/clean wood that is off the ground.
A second combo 18" combo I'd opt for a hard nose bar and round-back (chipper) chain. These take longer to dull in dirty wood but cut a little slower. The hardnose bat holds up better in dirtier conditions too. Example uses of this combo would be stump cutting and fence row clearing, or cutting on logs that have ben drug around and have dirt packed in the bark.
Thanks for the replies, guys.
This new saw is replacing my old friend: a 20 year old Stihl 025. Where does the time go??? That saw came with a 16" bar. So that is all I have ever known, for 20 years of cutting. I am wondering what the downsides might be if I just stayed with a 16" bar, since that is what I am used to?
Nick
   / Bar Length Recommendations #5
Nick
If you did not notice any downsides before, you will not notice any with your new saw.
   / Bar Length Recommendations #6
I didnt even run my 24" on my ported 357xp. For the NE 346xp 50cc JMO I would grab a 16" and a 20" or 2 18".
I like 16" on the 0-50cc saws in 3/8 or 325 in stihl RS chain and the 20" for back ups.
   / Bar Length Recommendations #7
As I get older, the shorter bars seem to suit me better. Ken Sweet
   / Bar Length Recommendations #8
I bought a 310 stihl and told them I didn't want the 20" bar. They said that'd be fine but it probably would cost more to go bigger. I said nope I want a 16" bar. I now own two stihl's with 16" bars, I use them for fire wood and logging for my mill. I have dropped trees 36" diameter with no issues except maybe having to walk to the other side to finish a cut :) At one time I owned saws with 24" bars, I'm perfectly content with the 16's
   / Bar Length Recommendations #9
Yep! A 24" is too much bar for a 346xp; I wouldn't go bigger than the 18 if it were me. The 346 is a great saw, you will be very pleased with the 18 & .325 set-up. I usually run a 20" on my 372xp and a 24" (& sometimes a 36") on my Stihl 056. I would opt for the dealer to supply a few more chains & some decent 2 cycle mix instead of an extra bar.
   / Bar Length Recommendations #10
I'd agree with getting a second 18" bar, as backup would be most useful.
Unless he'll give you a 50" bar and chain :) :) Tell him you want to try some milling :)
It wouldn't cut warm butter with your saw, but it would be worth about $300.
I've a 42" for my Stihl 660 for milling, and a 28" for regular use, but if I'm cutting with my 62CC saw a 20" is just great.
2006 Volkswagen Jetta Sedan (A50324)
2006 Volkswagen...
2013 Chevy Silverado 2500 HD (A52748)
2013 Chevy...
1990 GMC Topkick Grain Truck (A50514)
1990 GMC Topkick...
UNUSED JCT SKID STEER QUICK ATTACH 72" TILLER (A51244)
UNUSED JCT SKID...
2008 FORD F-250XL SUPER DUTY EXT CAB TRUCK (A51243)
2008 FORD F-250XL...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50323)
2011 Manac...
