Banson 3520 Hydraulic?
   / Banson 3520 Hydraulic? #1
park079
pine ridge, fl
Branson 3520
Mowing pasture when left front wheel would not turn; broken hydraulic line. Replaced line, filled hydraulic reservoir and started engine. No leaks front wheels turn OK. Raised bucket and 3pt mower, put in gear and went 3 feet and engine losses power, engine stopped and will not restart.
   / Banson 3520 Hydraulic? #2
Maybe your electric fuel lift pump got oiled or damaged? Sounds like no fuel to me.
Thank you; you were correct the fuel pump was trashed. Replaced pump, bleed system and away it went. The hydraulic line brake was unrelated.
2017 Makita HM1307CB 35lb Demolition Hammer (A52377)
2017 Makita...
2008 Doosan Mega250-V Articulated Wheel Loader (A52377)
2008 Doosan...
2018 FORD F150 Ext Cab 4X4 Pick-up Truck (A53422)
2018 FORD F150 Ext...
2011 Ford Mustang Coupe (A55758)
2011 Ford Mustang...
2005 Sterling Acterra Tender Truck (A55301)
2005 Sterling...
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
