I was given a very well taken care of Kubota BX235D. This tractor has a hydraulic leak on the bucket control valve banjo bolt fitting. They use orings on the top and bottom of the fitting where the banjo bolt screws into the control valve. It's leaking where the line is welded to the fitting, not the orings. The banjo bolt has a 1" hex head and 3/4" x 14 or 16 tpi on the bolt that screws into the control valve. I would like to know if anyone can give me the torque for the banjo bolt. I read on another post on another site that used orings in the fittings were torqued to 38ft lbs, but didn't give a bolt size, any help would be appreciated. If there is an administrator on this site you can email me an answer, or point me in the direction to find the torque. I have a shop Manuel for this tractor, and can't find any information about this.
