Bandsaw Blade Recomendations?
   / Bandsaw Blade Recomendations? #1
escavader
Veteran Member
western maine
bx-23 ,
The original blade that came on my CLARKE metal cutting bandsaw,i bought at TSC ,finally let go .Ibought the OLSEN one they had for a replacement.It dont cut half as quick as the old one.Can any one tell me where i can get a decent one?Thanks
ALAN
   / Bandsaw Blade Recomendations? #2
Ellis band saw blades and Timber Wolf are very good.I like5-7 vary tooth. Order on line.Framer
   / Bandsaw Blade Recomendations? #3
Try Fastenal variable tooth custom length shipped to your door.
Cuts fast & straight about $40 delivered.
   / Bandsaw Blade Recomendations? #4
On this same subject, anybody been successful in welding their blades together ?
   / Bandsaw Blade Recomendations? #5
use-Enco.com was one of the few places I could find the 90" blade my Kalamazoo uses. Ended up with an Irwin Bimetal which seems to cut pretty good. Found a 'coupon code' online for free shipping. :)
   / Bandsaw Blade Recomendations? #6
bimetal blades are best u can buy them to any size they last very long are more expencive but worth it, i use to buy 100ft coiles and weld the blades, was tough to weld.
   / Bandsaw Blade Recomendations? #7
I'm still using the Enco blade I bought a year or two ago.
   / Bandsaw Blade Recomendations? #8
I'v done them work some guys try but don't get them straight.
After making them for 30 years Ive gotten pretty good at it.
Having a good welder on the saw that jaws are in line is critical.
The grinder on the machine should be only used for blades kept flat and square on the end.
Inverting half the blade to grind end is important.
Getting the correct crush (with excess material for weld is tricky and different on different machines and blade sizes/ widths.
Proper annealing just as important as all the above.
The correct grinding go's a long way too.
tom
   / Bandsaw Blade Recomendations? #9
I think for a metal cutting band-saw, tooth count and proper alignment is more important than brand of blade or metal content.
The six-dollar blade that has been on my saw the last three years has made many many cuts and is still going strong.
They last me so long that I forget just what they are; I will have to look at the box the last one came in that is hanging on the wall so I will know what I use.
On any type of band-saw, whether floor-model wood-cutting band-saw, metal cutting band-saw, or band-saw mill, if a blade breaks during use, it is already full of stress cracks and should not be welded back together, as it will just break again at a different spot.
I am a firm believer in the TimberWolf blades for my band-mill and wood-working band-saw; I have not yet had reason to try them on my metal saw.:cool:
2014 Ford F-450 Altec AT200A 30ft Bucket Truck (A52377)
2014 Ford F-450...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB Crane Mechanics Truck (A52377)
2015 Ford F-350...
2020 International MV607 2,000 Gallon Water Truck (A51692)
2020 International...
2014 GMC Sierra 1500 Crew Cab Pickup Truck (A51692)
2014 GMC Sierra...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2020 FREIGHTLINER...
