Underdog57
Veteran Member
I have the LS 4041H with the LL 4101 Loader. The lift capacity at full height @ pivot pins is 2638#. My rear tires (R4 17.5 L x 24) are loaded with Rim Guard, according to the chart that adds 588# per tire x 2 = 1176#. The question is I am going to build a concrete counter weight (I am in the concrete business = cheap concrete) should I make a 1500# block or should I make one 1000# or somewhere in between. I will be doing mostly FEL work with bucket or forks so I will be leaving the weight on the tractor most of the summer. If I don't have a lot of weight on the loader will it be a problem to have 1000 - 1500# hanging on the 3 pt all the time ? My 3 pt lift capacity is 2665#
