Ballast in Tires
   / Ballast in Tires #1
wurso
New Hampshire
Hi Folks,
I sincerely appreciate the wealth of information provided by this forum. I am real close to making a purchase of an L3010 with FEL, Front Mount Snow Blower, 6' Rear Mower, Curtis Cab and Fuzzy Dice. I seem to be getting conflicting information from two dealers regarding ballast in the tires.
While they both agree that ballast in the tires is a good idea for what I'm using the tractor for, they disagree on the ballast material. The tractor will be located in the far reaches of Northern New Hampshire, just minutes away from Canada. Winters are long and severe, and it's not uncommon for the temperature to be 40 below zero.
One dealer recommends a 50/50 mixture of calcium and water in a tube in the tires. The other suggests an anti-freeze mixture in the tires. The dealer that recommends calcium says that anti freeze mixtures rots out the rubber tubes and tires. The dealer that recommends using anti-freeze says that calcium and water will eventually rot out the wheels.
Any ideas on what is best for ballast in the tires?
Thanks,
--Wayne
   / Ballast in Tires #2
You can avoid the problems by simply using cast wheel weight ballast. It costs more initially, but you never have to worry about the problems associated with liquid-filled tires.
   / Ballast in Tires #3
Hey , How are ya, I am up in the same area just across the Conn river in norhern VT. Cold it is!! I know many people with Kubotas as well as myself and I recommend loading your tires 3/4 full with windshied washer fluid. This is the best and if you look around you WILL find someone that fill them with this. This is a must, both the other guys are right Cal and antifreeze are a big no no. However I do recommend Tubes with all the rocks we all have as I log with my tractor and I reduce the tire pressure for traction and you never have to worry about popping the bead.
PS What is the price you got on your 3010 if i may ask? Did you look into the KIOTIs?? Are they junk, the prices are way great 18k for a 45 HP, loader,finish mower,tiller,brushhog,box blade and yes a dual axle trailer. Unbelievable, TOO GOOD TO BE TRUE???
Look forward to hearing from you.
Hendog
   / Ballast in Tires #4
wurso
Did the dealer who said anti-freeze would rot the tires say in what length of time? My B-7100 tires (all4)have been loaded with water, anti-freeze and #8 lead shot for approx 12 years. There's nothing showing(can't remember having to add air/w3tcompact/icons/wink.gif, and they look great on wash day with another(unrecommended by some posts) armorall. The dealer installed Rimguard in the new tractor (all 4)approx. 6 months ago, still kind of early to call on that.
regards
Mutt
   / Ballast in Tires #5
Wurso,
This is interesting. Ballast in tires has been dicussed numbers of times here on the forum and this is the first I recall anyone saying that an anti-freeze mix will rot rubber. Of course the calcium mix being hard on metal has been brought up, although that is why you use a tube with calcium. I thought that calcium mix was the standard for those who lived in your kind of cold. It would seem that you would need one heck of a lot of anti-freeze for 40 below.
I have been using anti-freeze for a number of years but, hey, I live in Georgia so what do I know about 40 below./w3tcompact/icons/smile.gif
MarkV
   / Ballast in Tires
Wow.... This is the first time that I've seen windshield washer fluid suggested. I guess there's no end to possibilities. You've got my imagination running wild... Perhaps Listerine, Gatorade, Thuderbird Wine..... Any other suggestions?
--Wayne
   / Ballast in Tires
Don't know the lenght of time for the various rots. But lead shot sounds interesting.
   / Ballast in Tires
Jack,
Thanks for the suggestion on the cast wheel weights. Any idea on price for these?
--Wayne
   / Ballast in Tires #9
Anti-freeze rots rubber? Maybe. I know eventually I have to replace the hoses on the truck and car, but I thought that was due more to the heat than the anti-freeze. Maybe RPM knows something about this. In the mean time. #8 lead shot? How did you get it in there? Does it go-- swish, swish-- when you drive?
SHF
   / Ballast in Tires #10
Anti-freeze doesn't rot rubber. Think about your radiator hoses and such. Other than the non-freezing aspect of anti-freeze, you also get the corrosion inhibitor package which will keep your rims looking like new (should you ever look at the inside of them). Some have mentioned the danger to animals if your anti-freeze laden tires spring a leak which leads to the environmentally friendly anti-freeze or RV anti-freeze (which will kill your grass if spilled). Calcium Chloride will definitely rot your wheels over time. So many choices /w3tcompact/icons/smile.gif
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A52705)
2012 VOLVO A40F...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A52377)
2021 Freightliner...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A54811)
2015 Toro Multi...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
