Ballast Ballast Box
   / Ballast Box #1
Harvey7
Annapolis Valley, Nova Scotia
Kioti CK25
I need to add some weight to the rear of the CK25, approx. how much weight do I need ? will be doing loader work.
Tks
Tina's husband
   / Ballast Box #2
At least 500 lbs on the 3ph for really good performance. But, then it depends on what you are loading in the FEL. Mulch is one thing. Stone is another.
   / Ballast Box #3
Tina, I'd check your owners manual for the loader, it should tell you what the required ballast weight should be. But 500# seems too light by 25% to 30% based on my own tractors, I would bet the recommended weight would be at least 650# to 700# of ballast.
Do us all a favor an check your owners manuals for the recommended ballast and let us know what the recommended weight should be for your tractor/loader.
   / Ballast Box #4
   / Ballast Box
Thomas said:
Maybe this site can help.
KIOTI HOMEPAGE
Thanks gentlemen, according to the homepage it should be 700 lbs, I also checked the manuel but it didn't say much other than to add ballast to the rear in the form of wheel weights or fill the tires.
tina's husband
91013 (A48082)
91013 (A48082)
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52141)
2018 INTERNATIONAL...
2015 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2015 Ford F-250...
2008 CATERPILLAR 345CL EXCAVATOR (A51242)
2008 CATERPILLAR...
UNUSED FUTURE MINI EXCAVATOR ATTACHMENT SET (A51244)
UNUSED FUTURE MINI...
UNUSED MOWERKING QUICK ATTACH ANGLE BROOM (A51244)
UNUSED MOWERKING...
