Ballast Ballast Box
   / Ballast Box #1
NYBOB
Maine NY(Binghamton area)
2007 JD 3720
I am taking delivery soon of a 3720. My dealer is out of JD ballast boxes and had to order it. In the meantime I have a ballast bar from my old tractor that has 500lbs of weights on it.
I see on my 300CX manual it calls for loading the tires which I did. 3 wheel weights per side and 1100 lbs of rear ballast.
I guess my question is, what should I put in the ballast box to get as much weight as I can? Will it be close to 1100 lbs? Also, I see there is an extension for the ballast box. How much more weight can I get into that?
Lastly, do I really need to put the 3 weights per side as it recommends?
Bob
   / Ballast Box #2
I have a 4110. I usually have a 46 backhoe, but when it's not on, I have only a ballast box loaded with rocks, no wheel weights or loaded tires. It's been sufficient for traction and stability. If you have loaded tires and a ballast box loaded with rocks or sand (something you can take out), you should be fine.
   / Ballast Box #3
If you want it heavy, fill it with PORTLAND CEMENT. You loader manual should list the estimated weights for sand, regular cement, and Portland cement-it's in my manual...
I have posted these #'s before also...
EDIT:
You can refer to THIS POST, I listed the figures my manual listed...
   / Ballast Box #4
If I were to buy a ballast box, I'd be hesitant to fill it with concrete or cement. I already have a pile of hard to get rid of concrete. Sand or dirt should work, maybe gravel.
   / Ballast Box #5
You will not get the BB to weigh in excess of 1000lbs with sand, gravel or dirt.
The OP asked:
   / Ballast Box #6
Okay there Kennyd,
The OP could throw 10 100lbs bags unopened of cement in there just to be precise, dig his project, and then use the cement and not have a 1000 pound block of concrete laying around. I was just trying to point out alternatives.
   / Ballast Box #7
Why not just fill the Ballast Box with portland and make it as heavy as possable. that is what its made for. I mean there is no reson you would ever want it to be lighter.
Chris.....:)
   / Ballast Box #8
The OP could also take the 500lbs of iron he already has and add 600lbs more weight to get his 1100lbs. I know I know, you guys love the cement.
I don't know if the iron would fit in the ballast box, but again it's only another alternative.
   / Ballast Box #9
If one fills it with cement, how can one use it to store garden tools when it is not in use???
John M
   / Ballast Box #10
My JD ballast box is filled with 7 bags of Home Despot's finest sand. Total weight is in the vicinity of 600# as I recall. Sand has another benefit if you are working in the snow and get stuck...you have plenty of sand to throw under the tires.
I did that a couple of times this past winter and put my folding surplus army shovel to use after many years of it doing nothing useful.
2020 Ford F-250 Ext. Cab Pickup Truck (A50323)
2020 Ford F-250...
(2) 250 GALLON POLY TOTES W/ CAGES (A51244)
(2) 250 GALLON...
John Deere 643 Corn Head (A50514)
John Deere 643...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2022 CATERPILLAR 249D3 SKID STEER (A51242)
2022 CATERPILLAR...
