Ballast block weight...how much is too much?
   / Ballast block weight...how much is too much? #1
mcfarmall
Veteran Member
Kalamazoo, MI
Kubota M5660, Farmall C, JD 260 lawn tractor
I have a 3PH dirt scoop and I'm going to build a concrete form to cast a block of concrete that can be placed in the scoop when needed and removed if for some reason I want to use it as a scoop again. The dimensions of the block are 23.5 inches wide x 36 inches long x 12-18 inches high.
A 16 inch high block will weigh around 1125 lbs and an 18 inch high block around 1300 lbs. Add the weight of the scoop itself, approximately 200 lbs. As I will have to pay for a full yard of concrete, I was thinking of making two of them, possibly two different sizes, so that is also an option. Maybe a 12 incher and an an 18 incher?
I'm planning on using it with a quick hitch on the rear of a Kubota M5660 as a ballast/counterweight for the FEL. Assume 14.9x28 R1 tires filled to 75% with Rim Guard on typical steel rims, not the ones with cast iron hubs.
So the question is, am I making the block too big or just right?
   / Ballast block weight...how much is too much? #2
At 3300 lift capacity, I would say too light. I use my LMC box blade with a weight block for a total of just under 1200 lbs. It's not too much weight for my L4330 40 hp FEL.
For a +55 hp tractor, I would look at 1500-2000 lbs personally.
As I TIC state sometimes: If your 3ph can lift it, it's probably too light.
Good luck.
   / Ballast block weight...how much is too much? #3
   / Ballast block weight...how much is too much? #4
It also has a great deal to do with where the center of mass is. Example - I have a 1010# Rhino rear blade on my 3-point. The COM is well beyond 24" behind the lifting point of the 3-point. With 1550# of RimGuard in the rear tires and the Rhino on the 3-point - I can carefully lift 3000# with the grapple on the FEL.
I never lift this much weight beyond 6" off the ground. Just enough so I can safely move the loaded tractor to its intended location. Many time I will leave "knuckle drag" marks when moving a large rock or chunk of Ponderosa pine.
Thanks for the replies all!
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
2014 GMC Sierra Pickup Truck (A50323)
2014 GMC Sierra...
PAIR OF PIPE RACKS (A52472)
PAIR OF PIPE RACKS...
2014 KENWORTH T800 (A52472)
2014 KENWORTH T800...
FAKE (A52472)
FAKE (A52472)
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
