Baling Hay With a Farmall 350 Gas
   / Baling Hay With a Farmall 350 Gas #1
elr0119
Hello all,
I have a 57 Farmall 350 that has been in my family for generations. Over the years, I have rebuilt it and it is in great shape. I use it regularly to plant 15 acres of corn and manage some minor work around the farm. It is a narrow front. Recently, I decided that I would like to have some cows and would like to bale a pasture that is 7-10 acres (depending how it is baled). The pasture consists of portion of flat land with most of the pasture on a 15 degree or slightly greater slope. Since I'm cheap, I wanted to use my Farmall to bale the hillside. Therein lies the problem...
I am being told that if I use the tractor to bale that I will likely flip and die. True or false? What factors play into this? What is meant by high center of gravity versus say a John Deere 3020?
Also, I'm being told that no square baler will work with that tractor. However, I see people using these tractors to bale on YouTube. What (old) NH baler models should I be looking for to run with this tractor?
Thanks for taking the time to respond.
   / Baling Hay With a Farmall 350 Gas #2
Hello all,
I have baled many a bales with a Super M and a 350 should be just as able.
I would much rather use a 3020 though.:)
   / Baling Hay With a Farmall 350 Gas #3
A 350 will be fine for what your doing. Ive used a Farmall H (less HP but same setup) for hay on hills and it does just fine. I use a 268 usually but on bad days i use a 68 i can also pull these just fine with my Ford 8N too.
Thanks to all for the feedback!
   / Baling Hay With a Farmall 350 Gas #5
I realize a lot of time has passed since you first posted but I want to say for years all we had to bale with was narrow fron end tractors. We did it with a 1939 farmall H, a 50's something farmall 350 Diesel and a farmall C. Again all had narrow front ends and we all survived. Everyone seems to talk "death" about "narrow frontends," My dad put me on one at 6 months of age and operating by my self at 5 years old. If they were not safe he wouldn't have kept them.
Be aware of your surroundings and pay close attention to what your doing and you'll be fine. Personally I miss not having a narrow front end tractor for working in the woods.
   / Baling Hay With a Farmall 350 Gas #6
Hello all,
Here's a little Farmall Super A running a square baler (the last minute of this 7.5 minute video).
YouTube - FARMALL Super A
   / Baling Hay With a Farmall 350 Gas #7
I used a 350 gas wide front end and a NH 68 square baler for several years until I upgraded. Tractor was plenty heavy enough that I did not feel baler plunger to bad.
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
WESSEX 1.5T LOT NUMBER 172 (A53084)
WESSEX 1.5T LOT...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
