Chains Baler Sprockets
   / Baler Sprockets #1
Nelson Farms
Mississippi
John Deere 5520 Massey Ferg 383 and 1035 compact
Got a John Deere 458 Standard baler and not sure if i need to change sprockets. Its been 4 seasons that since i had it :confused:
   / Baler Sprockets #2
It depends on how many bales you have made and how often you lubed the chains. Usually the sprockets will last through several replacement chains. Wrap a new chain around the sprocket and see how it fits. The chain should lay down in the bottom of the teeth. If it does not lay down in the bottom of the teeth all the way around, then it is time to replace.
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A52577)
2016 WESTERN STAR...
Hydraulic Power Unit S/A Towable Pump (A50322)
Hydraulic Power...
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
Case IH 1666 Combine (A50514)
Case IH 1666...
Rubbermaid 100 gal Poly Tank (A50515)
Rubbermaid 100 gal...
