baler problem
   / baler problem #1
jim242526
cumberland ri.
ford 5030
Baler is making a good knot but on one side the knot comes off the billhook leaving no twine on the twine disc and the twine then follows the bale out of the chamber and onto the ground leaving a long line of twine that is attached to the bale to the baler.
   / baler problem #2
Sounds like a tension problem with the hook. Personally I would take the manual and go through the entire knotter, set ALL of the settings SPOT ON and you will be able to do several thousand in a row without a miss. They are very finicky and need to be adjusted PERFECT for trouble free operation. Once the specs drift you will be chasing problems all over the place until you reset it.
   / baler problem
Thanks so much, When you said tension problem I followed the twine to the needles and found a loose porcelain eyelet just before the needles. I tightened it and now the knotter works fine. I'm thinking that every time needles moved the twine to the knotter the porcelain eyelet moved throwing off the mount of twine heading to that knotter off, making it sloppy, causing the problem. Small things like that can drive you crazy... Thanks again and hay away!!!
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A52128)
2016 Kawasaki 70...
2013 Honda CR-Z Hatchback (A50324)
2013 Honda CR-Z...
2019 PETERBILT 579 SLEEPER (A51222)
2019 PETERBILT 579...
2000 INTERNATIONAL 4300 17FT ROLLBACK TRUCK (A51222)
2000 INTERNATIONAL...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2014 Jeep Cherokee SUV (A50324)
2014 Jeep Cherokee...
